Got offered a 1980's 100wpc tube amp trade for my Anthem avm 40
polkfarmboy
polkfarmboy Posts: 5,703
edited January 2013 in The Clubhouse
I will post all the details as I get them, here is what I have so far. I have requested pictures and stuff but this is such a rare kind of brand I don't know how to value it. 100 wpc is just crazy and it should handle my Martin Logans way better than most current amps thats reasonably priced. Most of you guys here are super smart and have great audio detective skills so hopefully you can help as I get more info
OK, the Amp is a Grant Lumley an English Hand made Amp,made in the 1980's
By Grant Lumley's stereo power amplifier Co.
This beast can put out 90 watts down to 20hz and still has more!
it's 100 watt output Amp per. Ch.
tubes are in great condition and the hold unit just sounds so fine
35-45 watts sounds like 100 but soft
Post edited by polkfarmboy on
  • gdb
    gdb Posts: 6,012
    edited January 2013
    How are you planning to break it ? JK ! :cheesygrin: Good luck with it !!!
  • polkfarmboy
    edited January 2013
    I am still waiting for a response with pictures of it but as soon as I get them I will be sure to load em up
  • decal
    decal Posts: 3,205
    edited January 2013
    Ask yourself this, where am I gonna take this thing when I start having trouble with it. Just one of the things you should ponder.
  • polkfarmboy
    edited January 2013
    Well from what I have been reading so far about these amp is that most of them got imported here to the states through Canada and that the caps on them go bad and are very hard to come by in small quantitys they are oil caps? I was looking at them google pics that gdp put up and none of them have the dreaded WAF
  • gdb
    gdb Posts: 6,012
    edited January 2013
    Lots of places are tooled up to repair tube gear these days, the trick is to ferret out one that's within driving distance so that shipping isn't in the equation, IMO.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2013
    Circuits in old tube gear are usually quite simple. I'm an amateur at best with electronics but I entirely by myself (with some kind suggestions from folks here) modded, replaced all caps and resistors in my 1961 Eico ST-70. Just have to work methodically and have a little trouble shooting skill. Almost two years later it's still going strong with daily use.
    By the way, it's only about 40 wpc rms tubed and drives my SDA-1C's beautifully. You'll have lots of power for your speaks.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
    nooshinjohn Posts: 25,922
    edited January 2013
    You can't even plug in an Emo without electrocuting yourself. :twisted: j/k...Use extreme caution as English electronics often requir a fire extinguisher close at hand.
  • Tankman
    Tankman Posts: 419
    edited January 2013
    Does your AVM 40 have the upgrade?
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    I forget what your asking for the Anthem but I would think that Brit tube amp is worth less than a grand, maybe $600.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited January 2013
    You didn't mention it, but what tubes are in this Lumley ?
    And, as always .... PIX !
  • newrival
    newrival Posts: 2,017
    edited January 2013
    I recall reading something about a Grant amplifier that was highly praised, although I do not remember the model. paper/oil caps are not that difficult to come by if you needed to go that route. If it isn't p2p wired I might be concerned about delamination of ICBs or oxidation, etc, but I imagine it shouldn't be much trouble.
    enjoy your new amp
  • polkfarmboy
    edited January 2013
    Tankman wrote: »
    Yep I paid $800 for the upgrade
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2013
    I was just going to ask if it was recapped. If it wasn't and you decide to get it, it's not hard. Or just give it to a reputable shop to recap. As Fongolio mentioned, tube amp designs are fairly simple and easy to work on, so there are enough reputable shops that can work on them (amps, not integrated or preamps, which are difficult to work on and very easy to screw up).
    Whenever I get an old tube amp, I usually end up changing input and output connectors, power cord and electrolytic caps (you don't have to change non-polarized caps in 99% of cases).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • polkfarmboy
    edited January 2013
    Here is another reply
    Hi,that's Ok on saying no,on the Amp, as I really really don't want to sell it,even at 2K but I don't have an extra grand to spend on up grading my sunfire2 this week, maybe next week or next Moth,but no ground hum on this baby and the caps are not dry,It had a check up back in 2001 at BOHO electronics Hillside,NJ. A good friend in Sound reinforcement.I take great care of it like the wife appeal factor,she been with me from 75' Marred 82 until now 30yrs she know how I'm am about audio and Ham Gear.But if you send me a phone# I will take a Picture with my phone and sent it from there Tonight when I get in from work,good to message with you best regards
    tonyb Posts: 33,072
    edited January 2013
    I would say no PFB. Your anthem is worth more plus in the tube department, you could do much better for the coin.
