Soundbar 3000 Universal Remote
Indybears
Indybears Posts: 1
I just purchased a new Samsung 6100 Led TV and added the Polk Audio 3000 wireless sound bar. I love the set-up! Picture is great and the sound is even better. The problem is I am using 3 remotes. Comcast cable box, Samsung TV remote and the remote for the Polk soundbar. I am looking to purchase a universal remote like a Harmony or Universal Remote. Do you have any recommendations. Will both work or is one better with the Polk than the other?
I like the idea of using the computer to set-up the remote (Harmony) but cannot find info online if Polk supports this feature?
Happy in Indy.
Post edited by Indybears on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2013
    Hi Indy,
    Welcome to Polk's forum, I'm glad you're enjoying your SB3000. The best approach might be to consider teaching the Polk to respond to the Samsung's remote. Now the Polk will "speak" Samsung and so all you need to do is find a remote system that will control the cable box and Samsung.
    Regards, Ken
