Suggestions for plate subwoofer amplifier?
ViperZ
ViperZ Posts: 2,046
edited January 2013 in DIY, Mods & Tweaks
I have an old JBL PSW-D112 subwoofer box. The thing is a monster. Amplifier failed long time ago.
I replaced the speaker with the one from JBL S120PII studio series (450W or 500W RMS rated speaker).
I am planning to buy a new plate amplifier, replace the whole rear panel with the new MDF piece, then make a cut-out (and I'll keep the port).
What plate amps do people use?
1). I wanted to get Dayton 500W amp from parts express when it was on sale yesterday, but the shipping of $72 USD really kills the deal for me. There is one on ebay, so I may still have a chance to use it.
2). BASH amps?
3). Rythmik Audio?
4). Stealth Acoustics H series? (They have a distributor in Toronto!).
Any experience with the above amps? Any suggestions? Preferences?
Thanks!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
Post edited by ViperZ on
    treitz3 Posts: 19,992
    edited December 2008
    Here's a suggestion that you may want to entertain. You could try calling Polk and seeing if they would sell a DSW plate amp. I have no clue whether or not they'll do it but I do know this, it doesn't cost anything to ask.
    Just a thought. Good luck with whatever your decision may be.
  • zingo
    zingo Posts: 11,258
    +1 on the last idea. If you can swing the Dayton, it's a good choice. The Bash would do you fine also on the budget side.
  • mmadden28
    mmadden28 Posts: 4,283
    The PartsExpress ebay store has the 1000W Dayton @ BIN $320. You could bid and hope to stay low-or BIN with the MS 30% cashback and net it at $224. Its only $13 for shipping. And since you're buying direct, you get the 90 day warranty.
    They also have a rack mount version you could try and seal the back of the sub. This way you can use the amp elsewhere if you wanted to.
    Oh and if you decided to buy it from the PE website (nor refurb via ebay), you get free shipping
    ____________________
    Pool: Atrium 60's/45's
  • ViperZ
    ViperZ Posts: 2,046
    mmadden28 wrote: »
    Free shipping is for US only, unfortunately. They want $61-72 (depending on service) for shipping to Canada.
    Btw, what is their user id on ebay? Thanks!
    Edit: found it! http://stores.ebay.com/Parts-Express-Electronics
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • mmadden28
    ViperZ wrote: »
    Sorry, I didn't catch you location the first time around.
    I meant to include the link-I guess I missed that :o
  • 20hz
    20hz Posts: 636
    edited January 2013
    Is that sub amp the long skinny one ?
    if so nothing will fit
    Parts ex has free shipping at $100
    ViperZ wrote: »
    2). BASH amps?
    3). Rythmik Audio?
    Thanks!
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    ya'll know this thread is 4+ years old.
    Necroposters
