Equalizers
jim 249
Hi All; I did a search here and came up blank. I want to get an equalizer for my stereo to fool around with. They are not that expensive, although there is a lot of cheap ones out there. Any suggestions as to make and model to look for? Thanks for any help.:cheesygrin:
Post edited by jim 249 on
Hello, Jim. Although I would suggest not having one in the system, if you are looking for one....check out a Furman dual 32 band EQ. Out of all of the EQ's I have used, this one was very good and quiet.
The old analog EQs generally do more harm than good as far as I am concerned.
There are some pretty effective modern digital room correction gizmos (although I am not personally a big fan).
An inexpensive and fairly well reviewed piece (albeit one aimed at pro rather than home use) is the Behringer DEQ2496 Ultracurve Pro RTA/digital EQ. http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-661
Behringer's reputation isn't exactly sterling :-) but this particular product seems to be pretty decent. -
Try checking out Onkyo Integra EQ 35, very quiet and lots of capability for a inexpensive piece of gear.
Onkyo Integra EQ 35
Thanks, I will look for that one. I am using a Onkyo A-10 for my amp, so it might match up well. -
I've been using a ADC Sound Shaper III IC for several years now. Works great, very quiet, built like a tank.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I've been using a BSR EQ-3000 equalizer/analyzer for about 2 yrs now... But my application has the EQ between my sub-out on my receiver and the input for the CD on a separate integrated amp, that pushes my pair of Wharfedale W-60s. The only thing i'm shaping is the frequency(s) going to my "sub-woofers".
Otherwise I use no tone controls or EQ for my stereo channels - just "direct" tone control bypass "straight" or whatever term the manufacturer uses.
http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313&_nkw=BSR+EQ-3000&_sacat=0&_from=R40
I got mine off of craigslist for about $40 i think.Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
I also agree that the typical ten band anlog eq will do more harm than good to the sound. If you can run it in a tape loop and disengage it, that is a better option.
However, this does not mean that there is not a good way to use equalisation in a system. A parametric eq in the digital realm with a microphone and software to measure and adjust its effects is an excellent option. However, these cost more than picking up a basic EQ off the used market. But it allows you to compensate for room effects, and if you want to play with the sound, there usually is a way ot save multiple settings.
Regards
Mister Pig
