Opinion
VR3
I am thinking about changing my Fortress plates to accommodate a NL4 in the center of the plate.
So the binding post will be spread out a little more with a NL4 mounted in the center with the connection wired in line to the binding post...
So for instance you could do a bi-wire hook up or a one click connection for a NL4
What do you guys think? Would this be beneficial to anyone?
Post edited by VR3 on
I think you should kep it "standard", I see the benefit of the quick disconnect but I don't think alot of people would like making up the end for their own cables.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
That's what I was thinking but thought I would get an opinion
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Maybe both, with the the new idea as an option.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
That is the kicker, there would be only one option...
I think I will keep that option on the back burner :-P- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
