Power Cords...looking for suggestions.
pearsall001
pearsall001 Posts: 5,328
edited January 2013 in 2 Channel Audio
What have you guys used or are currently using. I'm interested in 5/6' length with a budget not to exceed $400. I'm sure there's plenty good one's out there without breaking the bank. I know this can get as dicey as discussing IC's, speaker cables, etc. I'm just looking for good information on what worked for you & I can do the reading on the various cables that you guys recommend.
Post edited by pearsall001 on
  • shadowlight
    shadowlight Posts: 327
    edited December 2012
    Talk to Pete at Triode Wire Labs - http://www.triodewirelabs.com/
    Lot more reviews on audiocircle
  • brgman
    brgman Posts: 2,859
    Also might want to check www.thecableco.com used section and get more bang for your 400 bucks.
    I’M OFFENDED!!!!
  • BlueFox
    BlueFox Posts: 15,250
    Anything by Shunyata. They are the power cable experts. At that price range look at this.
    http://www.musicdirect.com/p-9670-shunyata-venom-3-power-cable.aspx
    As mentioned, the Cable Company has better prices.
    Read their technical paper on DTCD and their other technical innovations.
    http://www.shunyata.com/
  • markmarc
    markmarc Posts: 2,309
    Shunyata Venom 3, hands down the best bargain power cord out there. Every piece of gear needing one has it.
    Former Staff Member TONEAudio
    2 Ch. System
  • Dawgfish
    Dawgfish Posts: 2,554
    Another option is to give Pepster here on the board a shout. He makes some really good sounding cables and power cords and the prices are very reasonable.
    EndersShadow Posts: 17,722
    Pepster is good as well as helipilotdoug who just got into the powercable game as well.
    F1nut Posts: 52,008
    PS Audio
  • schwarcw
    schwarcw Posts: 7,358
    I like PS Audio also. The detachable neutral prong is convenient if needed to match the wall outlet, or ground loop:smile:
    Carl
  • dkr919
    dkr919 Posts: 379
    Also try Pete Townsend -http://thewho.com/ - Knows every power chord in the book but I hear he can be a bit of a twit.
  • headrott
    headrott Posts: 5,496
    I have some DCCA power cords on my amp and power conditioner. The dynamics and bass significantly increased after installing these cords. You can easily get some used cords in your price range unless you absolutely want new. I recommend them:
    Link: http://dccaaudio.com/Home.html
  • Face
    Face Posts: 14,340
    Wireworld Aurora. Sound great and very flexible compared to most aftermarket cords.
  • pearsall001
    edited January 2013
    Well so far the Shunyata Venom 3 PC is looking pretty good. The Wireworld Aurora is also in the running. My only complaint about most of the PC's except the Venom 3 is that most of them are well under the 2M length that I need which is the stock length of the Venom 3. All the other cords once you factor in the added cost of going to a 2M cord length it starts to add up quickly. The Venom 3 with it's stock 2M lenght so far is the front runner. I haven't discounted all the other cords that you guys recommended though. And also the Venom 3 seems to receive a lot of impressive reviews as compared to the others in the same price category.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2013
    I gave Audience Powerchords a try last year and now have 3 of them. One for my amp, dac and power conditioner. I like'em because they sound so clear and open. I tried the "e" version and those cost a bit more and give you a bigger dose of the standard version. They are flexible. I also have a PS Audio Plus and the Audience is big improvement in my opinion.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    dkr919 wrote: »
    i hear he somehow managed to use a windmill to supply the power to some of those chords
  • wkjeffers
    wkjeffers Posts: 139
    edited January 2013
  • wkjeffers
    edited January 2013
    has anyone tried the Pangea power cables?
  • BlueFox
    edited January 2013
    wkjeffers wrote: »
    I have. In fact it was the Pangea cable that made me realize power cables can improve the sound. Shunyata goes to a higher level.
  • mister pig
    mister pig Posts: 28
    edited January 2013
    Recently i picked up some VH Audio inerconnects, and am extremely pleased with them. Chris is a very talented designer, and his prices are quite reasonable. I plan on buying a few power cords from him, and the prices are surprisingly low for what you get, well at least till you get ot his TOTL cable. He also builds differnt versions for specific applications. I plan on trying some of his cords out later this year.
    Regards
    Mister Pig
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    PS Audio gets my vote. Beware of counterfeits. I have been happy with the quality and the removable ground pin is a nice feature.
    Amazon sells them as well.
    txcoastal1 Posts: 13,519
    edited January 2013
    Patrick Cullen- power cords...Mike Cullen's son with Wyred 4 Sound
    Look up Cullen Cables on audiogon...several types and will do custom lengths
    patrick_cullen05@hotmail.com
  • wkjeffers
    edited January 2013
    is he a vampire too? (sorry to all the people who have not been forced to watch twilight yet!)
  • skrol
    skrol Posts: 3,464
    edited January 2013
    Not trying to hyjack...but... Is it beneficial to upgrade the hard wired power cords on older equipment that have the PC hard mounted? For example, my old Denon has what looks like heavy lamp cord. If doing such an upgrade, should I install an IEC connector on the back of the receiver or hard wire a better PC?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Systems
    Systems Posts: 14,872
    edited January 2013
    Vh Audio pc's would be my pick also, there are benenfits to his design.
    skrol wrote: »
    Stan
    They can be a PITA depending on how old they are.
    Most are PCB mounted, which is not hard, but the time and effort it takes to remove everything just to get to the power board, makes it a PITA!
    Some are simple, and some very time consuming and come with additional issues that have to be addressed (cleaning, lifting of traces, having to drill the pcb from the solder mask side, ect.).
    Again depending on how old it is, you would be lucky (without rerouting) to find room in the back of the chassis for an IEC cup.
    Just replacing the stock nickle plug on a "captive cord" component sounds better IMHO.
    A decent Marinco male plug will yield better sound than a nickle plug will.
    Unless the cable NEEDS to be replaced, installing a better plug is alot cheaper alternative.
    Testing
    Testing
    Testing
  • Speedskater
    Speedskater Posts: 495
    edited January 2013
    I thought that the main reason for IEC chassis connectors was to reduce manufacturing costs.
    edited January 2013
    skrol wrote: »
    Stan
    Putting the connector on the back gives you the option of trying different cords, who wants to hard wire every cord you try out ?
  • skrol
    skrol Posts: 3,464
    edited January 2013
    Any suggestions for DIY parts?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Face
    Face Posts: 14,340
    edited January 2013
  • mister pig
    edited January 2013
    Face wrote: »
    Sonic Craft is a good company, Geoff is a heck of a good guy there. I would recommend them also. VH Audio sells parts also and publishes a recipe for a DIY cord. A wide selection of parts can also be had from Micheal Percy, and last I saw he sold bulk XLO power cord and a wide array of terminations. The Bolder Cable Company builds a very good power cord also, and they are reasonably priced. I also believe Parts Connection in Canada has a lot of high quality DIY parts available.
    Regards
    Mister Pig
  • Systems
    edited January 2013
    mister pig wrote: »
    Regards
    Mister Pig
    :lol:
    Testing
    Testing
    Testing
  • larry777
    larry777 Posts: 480
    edited January 2013
    Is $100 for 2 excellent condition Shunyata Diamondback Power Cords worth it ?
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
