spikes on a sub
seabeerob213
seabeerob213 Posts: 1,843
edited December 2012 in DIY, Mods & Tweaks
and benefit to putting spikes on a sub, it will be placed on thick carpet with good pad, so trying to raise it up a bit and get something solid underneath,
Post edited by seabeerob213 on
  • seabeerob213
    just some normal spikes from parts express or somewhere similar
    treitz3 Posts: 20,047
    Yes. There is the benefit of not having the sub walk across the floor when using spikes on a carpeted substrate. They will also clean up the sound a tad by providing less "boom" with more accuracy. Adding substantial weight on top of the sub will helps things out even more. IME, this all depends on the size of the sub. Are you talking about a new sub(s) or one or more of the subs listed in your signature?
  • michael1947
    michael1947 Posts: 775
    I have a couple of subs that have bottom radiators and I have placed a large thick tile under them so the carpet does not absorb all of the sound. Seems to help.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • seabeerob213
    for the 2 channel in the signature
  • seabeerob213
    the psw 505's, the psw 110 has the included rubber feet and sits on a tile floor,
  • zingo
    zingo Posts: 11,258
    There should be a good benefit to spikes on a sub, and it should tighten up the response. I have two sets of 4 large spikes with threaded inserts from a project that fell through if you're interested.
  • seabeerob213
    sweet, im looking to use them when i go home to everett this feb so i will let you know when im int the area, i will be going to cali for about half the time im home though, so we gotta do it before the 21st, just trying to get the most out of my stuff, i cant be throwing 800 a month at audio gear, even if i have these past couple months, new cables, rti4's, csi3, ps3, psw 110, 2 channel receiver, 2 505's, and next month im looking to buy a pair of modded 7's from another member, but i told him not to hold them for me as i cant commit right now, but anyway yeah, im down for that zing, and if you can meet it can save us the trouble of shipping
  • deronb1
    deronb1 Posts: 5,021
    I have about 70 lbs of vinyl and CDs sitting on top of my sub. Super stable and sounds good!
  • seabeerob213
    i wont have anything on them save for my zune dock, haha, will that 6.34 ounces help? fyi all numbers are estimates, maybe i'll talk my dad into letting me use that sony 5 disc changer he's got, not the greatest, but the best cd player in the house
    I used to use a large glass cider jar [2 gallon] filled with coins. Anything with a decent amount of weight will help. With regards to your source, any improvement on the source will yield an improvement of the end result. 70 pounds of vinyl will definitely do the job!
  • seabeerob213
    im converting all my audio to lossless right now, anything on cd is getting wiped from my pc and re-ripped as wma lossless, and i transfer to my laptop over my wireless network, so i should have about 700 song converted to lossless by the time i get home, and theres plenty more cd's there,
  • zingo
    zingo Posts: 11,258
  • seabeerob213
    i havent received the PM, are you sure you sent it?
    F1nut Posts: 51,886
    I added Adona's Multi-Element Cones to my sub......oh hell yeah!!!
    These extra-large multi-element cones offer outstanding performance and are suitable for use with larger equipment. The lower portion is machined from solid brass while the upper portion is machined from Kevlar-filled composite.
    The cone assembly measures 2 inches in diameter by 2 1/2 inches tall. The lower brass portion is available in black, black-chrome, chrome or gold.
  • seabeerob213
    f1, that sounds sweet, any chance of a pic?
    F1nut Posts: 51,886
  • seabeerob213
    those look nice, maybe when i invest in higher end subs i can spring for those
