Bi-amp setup on T90e's, impedance?
z28chrismac
z28chrismac Posts: 7
edited December 2012 in Speakers
Does the impedance change if I am running a bi-amp setup? The t90e's are rated at 8ohm, but if you bi-amp it would make sense that might reduce to 6 or 4 ohms
___________________
350" 1080p 3D Mitsubishi projector
AVR: Yamaha RX-V2700
Mains: T90e's (bi-amped)
Center: CSiii
Surrounds: 2x T90e's
Subs: 2x PSW650
Post edited by z28chrismac on
  • tommyt21
    tommyt21 Posts: 685
    No, Fyi t90e is the same as m60's
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
    EndersShadow Posts: 17,688
    Bi-amping those speakers wont result in any kind of audible change to your system. Not worth the effort.
    I have those speakers and have "bi-amped" them in every possible way (off a reciever, off a dedicated amp, etc) and just not worth it.
