Sending Dared SL2000a in to repair hum
Stew
Stew Posts: 645
edited May 2014 in 2 Channel Audio
I've seen several threads lately talking about hum in the Dared SL2000a. Mine has always had a slight 60 hz hum but I convinced myself it was the nature of the beast. I tried lifting grounds, swapping cables, tubes, etc. but nothing changed the hum. It's barely noticeable from the listening position but very obvious a few feet from the speakers.
After reading that some are essentially silent, I contacted Joe at Dared for advice. He suggested I contact Mike at Deltronics in Woodridge, IL. I'll box it up tomorrow or Friday and send it in. Unfortunately, the warranty's up so I'll eat the repair bill. My own dumb fault for not dealing with this sooner. Mike will contact me with a diagnosis before making repairs. I'll post his findings when I hear.
I'm also sending the Auricap input caps I purchased but never installed. Mine has the rectangular input caps flush mounted to the board so I'd have to get access to the back of the board to install. Mike said he can install while he has it apart.
SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605
Post edited by Stew on
«13
  • audio_alan
    audio_alan Posts: 770
    edited December 2012
    Please keep us updated on what happens with your unit. If it does turn out to be a defect, maybe mine suffers from the same thing. My sounds like your's - the hum isn't very noticeable from far away, but up close it's obvious.
    As a side note, strangely I was able to get mine to stop humming, but that was when I accidently plugged in a dvd player's outputs into the dared's outputs (instead of the dared's inputs). However, after realizing my mistake and hooked it up correctly, the hum came back (bummer!). I'm wondering if mine isn't just a ground loop problem...
    heiney9 Posts: 25,440
    I have talked with Mike and bought an amp from him. A local polkie also had a cap replaced in his Dared and Deltronics did the work. They seem to be very good.
    Good luck
  • schwarcw
    schwarcw Posts: 7,358
    Stew, do you have an antenna hooked to a tuner or receiver in your system? Or possibly a cable TV box that's connected into your audio system in some manner. These can cause hum!
    Carl
  • daboyz
    daboyz Posts: 5,207
    That was my Dared and they did a very nice job. You're in good hands.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Please let us know how it turns out! I have one with the same issue, but it sounds like mine is more severe. I hear not only hum, but noise from my computer (on the same circuit), AND I'm running an APC H15 power conditioner.
  • Stew
    Stew Posts: 645
    edited January 2013
    H9/daboyz - Glad to know I'm in good hands with Mike at Deltronics. They just called to let me know it arrived and get a deposit.
    Carl - I do have a cable box that's connected but I disconnected everything and hooked up preamp, amp, and speakers only - with and without cheater plugs. Still hums when preamp is turned on.
    audio_alan, audiocr381ve, etc. - Deltronics estimated 1 to 2 weeks for a diagnosis. I'll keep everyone posted.
    Happy New Year!
    1000VA Dreadnought
  • audio_alan
    edited January 2013
    Good deal, Stew. I hope it works out and the fix isn't too expensive.
  • audiocr381ve
    edited January 2013
    Any word on this yet?
  • Stew
    Stew Posts: 645
    edited January 2013
    I haven't heard anything yet. I'll call next week if I don't hear from them.
    1000VA Dreadnought
  • erniejade
    erniejade Posts: 6,321
    edited January 2013
    I live 5 Min. from Deltronics. They have always done good work for me. I have had a lot of boomboxes ( i collect them) on down to my velodyne spl1200 hum fixed there. Nice people there. If something isnt right, don't be afraid to call them either. They will make sure you are taken care of after a repair also.
  • erniejade
    edited January 2013
    I forgot to mention, if you live in the area, make sure you stop up the street at Holm Audio!
  • audiocr381ve
    edited January 2013
    Stew wrote: »
    Great, please keep me posted! Mine is out of the system until I can fix that hum.
  • Stew
    Stew Posts: 645
    edited February 2013
    I spoke to Mike earlier this week. He heard a slight hum but hasn't been able to duplicate what I was hearing. He did find and repair some questionable solder joints in the power supply that could have been the culprit. I'm wondering if he has cleaner power in his shop and therefore less hum to begin with. I'm hoping that I'll hear a bigger improvement.
    He's trying to locate an NAD amp so he can duplicate my setup. I appreciate the effort and will wait patiently. I'm really going to be baffled if it still hums in my system! Time will tell. I'll keep everyone posted.
    1000VA Dreadnought
  • audiocr381ve
    Stew wrote: »
    Bummer, I was hoping it would be something more obvious. Thanks for checking in!
  • Stew
    Stew Posts: 645
    edited March 2013
    My Dared is on the way home. Mike at Deltronics checked all the capacitors in the power supply, cleaned up solder joints (power supply, inputs, outputs and volume control) and installed the Auricap input capacitors I supplied. He says the noise floor is within spec and as low as he can get it. He only hears a hum if he's close to the speakers. It should be here Wednesday and I'll be anxious to see if the hum is less in my system. If not, I either missed a ground loop or it doesn't play well with my amplifier. I'll post the results. By the way, Mike charged about $140 + shipping. Seems more than fair for the effort.
    1000VA Dreadnought
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited March 2013
    I hope your guy got things fixed for you.
    His price seems reasonable,how many caps did he replace?
    Knock on wood mine is still quiet.Hope yours is too.
    Dan
  • Stew
    Stew Posts: 645
    edited March 2013
    It arrived Wednesday night and I finally got a chance to listen today. Hum seems a little better but still there.:sad: It's really not that bad but I would like to find a solution. I'm using the amplifier portion of a NAD C370 integrated amp. There was no hum at all when I used the preamp in the C370. Any thoughts on whether a different amp might help?
    Dan - He replaced the two input caps with Auricaps. It's been a while since I've listened to it but the Auricaps sound incredible!
    1000VA Dreadnought
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited March 2013
    I dont think ANY hum is accecptable. Mine has never hummed its dead silent.might want to roll some tubes just in case. Dont know if they can cause a hum but the unit should not!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Stew
    Stew Posts: 645
    edited March 2013
    On a whim, I just hooked up my Yaqin tube buffer between the Dared preamp and NAD amp.
    In my old system, the tube buffer still passed the signal through when turned off but speaker output was lower. The gain is 1 when turned on.
    I first tried the tube buffer between my Dared and NAD with the tube buffer off. The hum is almost entirely gone! I have to turn the volume knob on the Dared up more to get the same volume but there's no hum. With the tube buffer turned on, the hum comes back.
    Do I need an amplifier with a higher input impedance? Someone who understands tube buffers/amplifiers better than I do please help!
    1000VA Dreadnought
  • Oldfatdogs
    edited March 2013
    Hello stew,I'm glad your upgrade on the caps showed improvement.I would try another amp if you have access to one,cant hurt to try.Like soundfreak, I would roll some different tubes just to see. Wish I could be of more help,Im sure others will chime in here.
    Dan
  • Systems
    Systems Posts: 14,873
    edited March 2013
    Have you tapped on the tubes with a pencii when in use?
    Testing
    Testing
    Testing
    edited March 2013
    Not recommended to do that!! Tubes and the internals are delicate and should not be tapped, especially when in use. What does that prove anyway? If the the OP hasn't already; you can power down the unit remove and reinsert the tubes, on occasion this will get rid of humming or static. I would assume as long as the OP has had this issue, he has done that and also tried various other tubes to eliminate tubes as the source of his problem. That should be the first thing one does with a tube piece.
    Auricaps are simply wonderful. I feel for the guys who bought the later models because they don't come stock anymore. It really improves the performance of the Dared SL2000A
  • Stew
    Stew Posts: 645
    edited March 2013
    I've tried it with original and upgraded tubes, cleaned pins, etc. all to no avail. A better wall socket couldn't hurt but it's plugged into a Panamax conditioner. I've tried it with and without the Panamax and it doesn't change the hum.
    What effect would a tube buffer that's turned off have? (See Post 20) Would it increase the input impedance? If so, I need to look for an amp with a higher input impedance. Thoughts??
    1000VA Dreadnought
    Toolfan66 Posts: 18,067
    edited March 2013
    My dared has never been dead quiet, as a matter of fact I don't think I have ever had any tube gear that was dead quiet except my phono pre.
    Not that it was a loud hum on any gear..
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited March 2013
    Same here. I've owned two Dareds mated with a variety of amps and speakers in three different residences with different tubes and have ALWAYS had a slight hum. Nothing obnoxious. And nothing I can hear once the music starts. Just my experience....
  • Stew
    Stew Posts: 645
    edited March 2013
    With the tube buffer in line but turned off, the hum is there but I have to be within a couple of feet of the speakers to hear it. That would not bother me. Without the tube buffer (or with it turned on), the hum is slightly audible from the listening position during quiet passages. That does bother me.
    The more I think about the tube buffer in line but turned off, I assume it is effectively decreasing the gain of the preamp. How would I lower the gain of the Dared? I'm not sure I want to do that but would like to know what's involved. The other option would be to find an amplifier that handles high gain better than the NAD. What specs do I look for in an amplifier that will handle high gain? Any brands that seem to handle high gain better than others? Thanks for the help!
    1000VA Dreadnought
  • daboyz
    daboyz Posts: 5,207
    edited March 2013
    I'm sorry to say that your Dared is toast and you should just sell it. I'll give you $20 for it.:wink:
    I'm trying to remember but I had to send it in is because one channel hummed to the point where it was unlistenable. If it's not there when the music is playing then I wouldn't worry about it. The Auricaps are sweet.
  • Systems
    edited March 2013
    My thoughts where the micros......
    That said, if there is a major problem doing this........then you have other problems.
    Comprende?
    Testing
    Testing
    Testing
  • audiocr381ve
    edited March 2013
    So I swapped my Polk Monitor 5's for a pair of Magnepan MG10's and can't hear a hum anymore.... Very strange.
    The hum coming out of my Monitor 5's could be heard easily from my listening position. With the Maggie's swapped in, the hum is gone.
    OP, have you tried swapping in a different pair of speakers?
  • Stew
    Stew Posts: 645
    edited March 2013
    I'd be willing to bet the Maggie's have a lower input sensitivity than the Polks. I think this is starting to make sense. From the research I've been doing tonight, a high amplifier input sensitivity (v) requires a higher volume setting to achieve the same sound level. A low speaker sensitivity (db/watt/meter) also requires a higher volume setting to achieve the same sound level. Either will reduce the noise floor.
    I'm glad you found a solution but I'm not interested in different speakers. I need to look at the amplifier. My NAD has an input sensitivity of 1.1v. I've seen some amps as high as 1.75 v. Another option might be in-line attenuators (Rothwell, Goldenjack, etc.) but I'm concerned they might degrade sound quality. Any thoughts appreciated.
    1000VA Dreadnought
