what fuse to get for Polk Monitor 10A speakers?
I need to gert a new fuse for one of my Polk MOnitor 10A speakers and I do not know what size fuse to get.
I have seen different sizes mentioned for the Monitor 10A, such as .75 amp fast or 1 amp fast.
Does anyone know what is the correct fuse I need to get?
Thank you.
Thank you.
Post edited by pglbook on
I checked the fuse I took off of the speaker and it seems to say AGC 1 1/2 (one and a half). Could that be correct? That is much different than the .75 and 1 amp fuse that was mentioned elsewhere. However, it is hard to read what is on the fuse, of course. I'd appreciate it if anyone had info on the correct fuse I need to buy for the Polk Monitor 10A. Thanks,
The schematic calls for a 1 amp fast blow fuse.
Thank you. Yes you are correct. The correct fuse is a 1 amp fast blow fuse. I digged out the original manual that I was given with the speakers when I boght them a little over a year ago and it does say a 1 amp fast blow fuse. I wasn't sure if I'd be able to find the manual so I submitted this post. Funny thing is that the fuse that the prior owner had in them was a 1 1/2 amp fuse and not a 1 amp fuse. I went to Home Depot and bought 1 amp fuse.s because that is what it calls for. Should I change fuses in both speakers from the 1 1/2 amp fuses to the new 1 amp fuses? Does it make a difference? Thanks again for your posts,
fuses are cheap, yes put new correct values in both.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
I have original monitor 10 speakers and running new yaqin mc 10l amp which keeps blowing fuses . This model of course has two fuses and when I went to replace the fuses the top fuse was a 250 m amp and the bottom a 1 amp ? What are the correct fuses cheers
