Looking under the hood
1313234363742
  • cstmar01
    cstmar01 Posts: 4,424
    edited December 2012
  • nspindel
    nspindel Posts: 5,343
    Dared MC-7P, stock:
    And after I upgraded the coupling caps:
  • zingo
    zingo Posts: 11,258
    cstmar01 wrote: »
    Very nice BAT...
  • cstmar01
    zingo wrote: »
    Very nice BAT...
    Thanks! Not sure what happened to my pictures as it got upside down and I'm missing some.
    SCompRacer Posts: 9,112
    cstmar01 wrote: »
    I just flipped the old laptop over....:cheesygrin: Nice BAT Chris!
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Nudies from my equipment collection:
    Class
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2013
    Excellent pics Glen! I actually saw something in the Phase Linear picture that shows an item I have on a Soundcraftsmen amp. Looks like a starburst shaped sleeve that's on the little capacitors??? Are they for cooling? That Outlaw Audio M200 amp looks like it would be sweet for a center channel amp.
    mhardy6647 Posts: 34,998
    edited March 2013
    The things you describe are indeed heat sinks, to dissipate heat. They are usually found on transistors and/or integrated circuits (i.e., active devices) that dissipate some heat, not on capacitors. Some power resistors will have a similar structure, typically built in to them.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited March 2013
    Marantz 2265B
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Polkie2009
    edited March 2013
    Thanks for the info mrh, I looked closer at Glen's pic of his Phase Linear and the heatsinks are on something that looks more round and flat and not cylindrical like a cap. :wink: I really admire how the Japanese made their electronics so well organized under the hood.:). That Pioneer looks beautiful.
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Polkie2009 wrote: »
    Yes, the starbust shaped sleeves are heatsinks, placed on the driver transistors to dissipate heat. The top Classe picture and the SAE2400 also have ones that are clearly visible. In the Class
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Some more nudies:
    Marantz SR19 receiver w/fan-cooled outputs
    Yamaha C-60 preamp
    Nikko Alpha 2000
    Class
  • blairfrischx
    blairfrischx Posts: 259
    edited March 2013
    Just because I love looking inside of it: Stello DA100 Signature DAC
    Face:
    Ycf5vdO.jpg?1
    Inside:
    Some other pictures of inside (link)
  • Glen B
    Glen B Posts: 269
    edited April 2013
    Denon DP-59L
  • Glen B
    Glen B Posts: 269
    edited April 2013
    Audiosource AMP100, 60W x 2/ 150W bridged.
    Audio_100_01_zps03ba5495.jpg:original
    Amp-100_01_zps0c8aeabb.jpg:original
    Amp-100_03_zpsbc1dbcfb.jpg:original
    Amp-100_02_zps5e21ac25.jpg:original
  • zingo
    zingo Posts: 11,258
    edited May 2013
  • Glen B
    Glen B Posts: 269
    edited May 2013
    What is the make and model amp pictured ?
  • zingo
    zingo Posts: 11,258
    edited May 2013
    My new custom Gary Dodd amp using Hypex modules on a balanced power supply, both with separate switches; 200wpc 8ohm, 400wpc 4ohms and no noise. :cool:
    pitdogg2 Posts: 27,035
    edited May 2013
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Saweet
    Thanks! I love the simplicity of it!
    edited May 2013
    Man just goes to show can't judge an amp by it's appearance. That thing looks like a knock off adcom :smile:
  • FTGV
    FTGV Posts: 3,650
    edited May 2013
    Thats because it is a repurposed Adcom chassis with a pair of these http://www.hypex.nl/product/ucd-amplifier-modules/ucd400st.html and a custom linear power supply.
    edited May 2013
    FTGV wrote: »
    Well that explains it completely and by no means was I knocking that amp.. Thanks Fred
    Ivan
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2013
    Forgot about this thread, anyways here is my anthem mca5 series 2 just for a look. One power supply for the 2 mains and one supply for the center and rears
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Very clean layout on that Anthem!
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited June 2013
    Behind the face plate:
    EndersShadow Posts: 17,704
    edited June 2013
    Harman Kardon Citation 11 pre-amp:
    Total interior:
    Front Panel:
    Rear Panel from Power connector to aux power connections
  • zingo
    zingo Posts: 11,258
    edited June 2013
    Hand soldered? Very nice....
  • lanchile
    lanchile Posts: 560
    edited June 2013
    Total interior:
    Front Panel:
    Wow, I love how they used to build gears like this one. a lot of shielding for sure!!!. it is a shame that many companies do not want to spend in "extra" metal or quality parts and have pride to show the inside of their gears. Most the time you will find a very nice amp, receiver etc, etc that look very nice from the outside, but as soon as you open it, you will find it's low quality build. Business, business, business...:rolleyes:
    Make it simple...Make it better!
    edited June 2013
    One Class A Krell KSA-250. 140 pounds, 4.5kVA transformer, 250WPC @ 8 Ohms, stable to 0.5 ohm at 4,000WPC.
    There were three revisons of this amp. First build had vertical binding posts, second version sported horizontal binding posts and different soft start board with no separate low voltage power supply to activate the relays. This is the third revision with higher bias and some board changes.
    Once upon a time Krell would mod these into mono blocks.:eek: I know a fellow here that has a pair of these converted to mono blocks. I bow to him.:cheesygrin:
