New hardwood bases for my SDA 1B's
kidglove13
Well I decided to finally make new hardwood bases for my SDA 1B's and get rid of the garbage particle board bases.
I used 3x3 oak stock mitered glued and screwed to the bottoms of the cabs
I used some generic spikes I had lying around
Because of where the speakers sit they are on hardwood floor so I put pennies under the spikes to make positioning the speakers easier, the spikes alone sank into the hardwood floor to much
With the pennies under the spikes the speakers slide alittle easier but you still need to muscle them a bit to get them to move
The setup is very solid much better now
Man these things are heavy
Cheers
Cheers
Post edited by kidglove13 on
Very nice. You can get metal floor protectors made specifically for speaker spikes that function like your pennies but are cup-shaped, so there's no risk of the spike slipping off.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
I use pennies. I used a small drill bit to mark a spot in the middle to keep the spike from moving.
It has worked for years. -
What is the "point" of spiking speakers to an object that cannot couple to the floor due to it's own uneven surface?
What he asked!!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
KG, PM me your address and I'll send you some of the base plates. I've got two dozen left over from custom installs where I drilled beveled holes into the pedestal shelves that we built for the speakers. These are from the blk chrome ones P.E. sells, about the size of a penny with a centered tapered hole for the point. I usually stick the sorbathane washers on these to keep them in place.
They look very nice. I have been wanting to do that for my RTA12c's for a while now. How high did u raise them up?Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Looks good, I totally did away with the bases on mine and put the spikes directly into the bottom of the speaker.Denon PMA-900V
Linn Axis with Grado Red
Cambridge Azur 650C
Polk SDA-1BTL
