New hardwood bases for my SDA 1B's
kidglove13
kidglove13 Posts: 207
edited December 2012 in Vintage Speakers
Well I decided to finally make new hardwood bases for my SDA 1B's and get rid of the garbage particle board bases.
I used 3x3 oak stock mitered glued and screwed to the bottoms of the cabs
I used some generic spikes I had lying around
Because of where the speakers sit they are on hardwood floor so I put pennies under the spikes to make positioning the speakers easier, the spikes alone sank into the hardwood floor to much
With the pennies under the spikes the speakers slide alittle easier but you still need to muscle them a bit to get them to move
The setup is very solid much better now
Man these things are heavy
Cheers
Post edited by kidglove13 on
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2012
    Very nice. You can get metal floor protectors made specifically for speaker spikes that function like your pennies but are cup-shaped, so there's no risk of the spike slipping off.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    I use pennies. I used a small drill bit to mark a spot in the middle to keep the spike from moving.
    It has worked for years.
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2012
    What is the "point" of spiking speakers to an object that cannot couple to the floor due to it's own uneven surface?
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Schurkey wrote: »
    What he asked!!!
  • dracoskeeper
    dracoskeeper Posts: 142
    KG, PM me your address and I'll send you some of the base plates. I've got two dozen left over from custom installs where I drilled beveled holes into the pedestal shelves that we built for the speakers. These are from the blk chrome ones P.E. sells, about the size of a penny with a centered tapered hole for the point. I usually stick the sorbathane washers on these to keep them in place.
  • soundfreak1
    soundfreak1 Posts: 3,414
    They look very nice. I have been wanting to do that for my RTA12c's for a while now. How high did u raise them up?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • bigaltx24
    bigaltx24 Posts: 141
    Looks good, I totally did away with the bases on mine and put the spikes directly into the bottom of the speaker.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
