Subs, Subs, Subs Which ones to buy? The best band for the buck
I'm running a onyyo 709 with a new xpa-5 and lsi15, lsic, lsic7,lsif/x speakers. My room is 24 X 24 with 120" screen and a jvc 550 projector. Watch a lot of movies and some tv. Have a old psw650 sub. Many of you on this form tell me I need a new sub. Can I do it on a price range of 500.00 to a 1000.00. Would consider a good used one. I see alot of you like hsu or svs. Which ones do you like? Where is the best deal on the ones you like? Thanks Dave
Post edited by DAVE HOFFER on
  • tommyt21
    tommyt21 Posts: 685
    edited December 2012
    Hsu vtf-15 is in your price range and suited for a room of that size. Epik Empire would also be in that budget
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • -Stanley-
    -Stanley- Posts: 44
    +1 for the HSU sub.
  • steveinaz
    steveinaz Posts: 19,545
    When you talk bang-for-the-buck, you should consider SVS. Even their least expensive subs are far from "entry level."
    I have an extremely "modest" PB12-NSD sub paired with $3600/pr monitors---and I am very pleased with the quality/performance.
    EndersShadow Posts: 17,707
    Yup, look at their PC line as well. Same performance as the box subs but in a cylinder so its less expensive to build a ship. Save some money and get the same performance!
  • ken brydson
    ken brydson Posts: 9,005
    imdggisknx reported
  • slider2828
    slider2828 Posts: 118
    I like castle subs which are nice too... Not too pricey
