How easy is it to tell...
....whether a SRS speaker has the sl 3000 tweeter or the sl 2000 tweeter?
How important is the original crossover cable?
What does it do exactly?
Can you buy something that would work as well?
-Luc
-Luc
Post edited by trubluluc on
Having the original cable is not super important, new ones can be made. Some here have made them and/or have instructions on how to make them. The cable facilitates SDA, read here ... http://www.polkaudio.com/home/products.php?category=3&speaker=274&vintage=1 and here http://www.polkaudio.com/home/technology/sda.php?category=3&speaker=82
The SL2000's look like this ... -
The 3000's look like this ...
Just what I needed to know.
So if I'm understanding this right, the connector is used when using separate amps without a common ground to drive each speaker?
-Luc -
That picture looks oddly familar...
1.2tl --
Crossover has one nut in the center..like a bolt- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
See ... there ya go again ... you have a talent for being like a kid in middle school that can't keep from making his own signs to put on his own back that read ... KICK ME ... I have a feeling that when the time comes that leather, whips and chains will not be strangers in your sex like ...
ah, that is where that picture came from eh...
nice...
out of all the ones to save...
you saved that one :eek:- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I saved nothing ... I gathered them today from what I could find on eBay active and/or completed
