Polk Audio Monitor 10 (Vintage) Crossover Modification Thread
VR3
Castle Stack
Tweeter Network -
Clarity Cap ESA
Mundorf Mox
Midbass Network -
Clarity Cap SA
Point to Point Wiring
Upgraded binding post
Should be fun!
Tweeter Network -
Clarity Cap ESA
Mundorf Mox
Midbass Network -
Clarity Cap SA
Should be fun!
Post edited by VR3 on
Nice caps. Tjat should do them justice! They will need at least 100hours or so to break in but they just get better and better.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Looking good Trey, can't wait to put the required time on them!!Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
I think this turned out COOL!
Looks like something out of Iron Man!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
More pics!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
just curious when you do a point to point mod like this.... are the leads on the caps/resistors always long enough, or do you sometime need to extend them with wire? wonder what you might use of so, and what you do use for internal wiring, if i may ask.
thanksPolk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
very cool TreyRec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
I think you should change your screen name to 3D because your mods seem to take on a very "cubist" aesthetic. And they're always BIG! lol
Nice work!
Thanks guys!
Looks great! Can't wait for a review of how it sounds!HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100 -
And I thought the SoniCap Gen 1's I put in my 10B's crossovers where big
I was just thinking make them look like cans of your favorite Beer.
Radio Station W7ITC -
I have always thought if I could find huge tech flex to incase my mods in they would look that much cooler... but nothing that would look good enough or be cost effective- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They make Tech-flex casing up to 5 1/4 inches in diameter.Radio Station W7ITC -
Curious as to what the peg board material is actually named and if you just go cap lead to cap lead here or if there is wire. Can't quite tell from the pics. Thanks.Polk Lsi9
Keces DA-131 mk.II
The board is called perfboard... The wiring is ptp... So lead to lead or wire extension- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks a lot.Polk Lsi9
Keces DA-131 mk.II
