Polk Audio Monitor 10 (Vintage) Crossover Modification Thread
VR3
VR3 Posts: 29,538
edited December 2012 in DIY, Mods & Tweaks
Castle Stack
Tweeter Network -
Clarity Cap ESA
Mundorf Mox
Midbass Network -
Clarity Cap SA
Point to Point Wiring
Upgraded binding post
Should be fun!
Post edited by VR3 on
  • soundfreak1
    soundfreak1 Posts: 3,414
    Nice caps. Tjat should do them justice! They will need at least 100hours or so to break in but they just get better and better.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • jimsvm
    jimsvm Posts: 307
    Looking good Trey, can't wait to put the required time on them!!
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
    VR3 Posts: 29,538
    I think this turned out COOL! :)
    Looks like something out of Iron Man! ;)
    VR3 Posts: 29,538
    More pics!
  • 11tsteve
    11tsteve Posts: 1,166
    just curious when you do a point to point mod like this.... are the leads on the caps/resistors always long enough, or do you sometime need to extend them with wire? wonder what you might use of so, and what you do use for internal wiring, if i may ask.
    thanks
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • jimsvm
    jimsvm Posts: 307
    very cool Trey
    I think you should change your screen name to 3D because your mods seem to take on a very "cubist" aesthetic. And they're always BIG! lol
    Nice work!
    cnh
    VR3 Posts: 29,538
    Thanks guys! :)
  • gmjungbluth
    gmjungbluth Posts: 232
    Looks great! Can't wait for a review of how it sounds!
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    Rear: Paradigm Atom V3
    Center: Boston Acoustic VR12
    Sub: Bowers & Wilkins ASW600
    2Ch:
    Restored Fisher 500C
    Yamaha P-500 Turntable
    Living Room:
    Harman Kardon 3380
    Restored Polk Monitor 7B
    Bedroom:
    Harman Kardon VR-3750
    Cambridge Soundworks Ensemble
    Polk PSW10
    In and out of rotation:
    KLH Model 6,
    Polk LSI7
    NAD 7100
  • transmaster
    transmaster Posts: 424
    And I thought the SoniCap Gen 1's I put in my 10B's crossovers where big :smile:
    I was just thinking make them look like cans of your favorite Beer. :wink:
    Radio Station W7ITC
    VR3 Posts: 29,538
    I have always thought if I could find huge tech flex to incase my mods in they would look that much cooler... but nothing that would look good enough or be cost effective
  • transmaster
    VR3 wrote: »
    They make Tech-flex casing up to 5 1/4 inches in diameter.
    Radio Station W7ITC
  • 11tsteve
    Curious as to what the peg board material is actually named and if you just go cap lead to cap lead here or if there is wire. Can't quite tell from the pics. Thanks.
    Polk Lsi9
    Keces DA-131 mk.II
    VR3 Posts: 29,538
    The board is called perfboard... The wiring is ptp... So lead to lead or wire extension
  • 11tsteve
    Thanks a lot.
    Polk Lsi9
    Keces DA-131 mk.II
