I need a preamp with spdif output
Ern Dog
Ern Dog Posts: 2,237
edited December 2012 in Electronics
I'm looking for something that I don't think exist, but here it goes:
I'm looking for a 2 channel preamp with 2 digital inputs and a spdif output AND it needs to have a remote volume control. I'd use it connect my cable box and Oppo to my Overdrive dac.
I need this for two reasons. One is that my Overdrive dac/pre doesn't have a remote and the other reason is that it only has 2 inputs. One is a USB (which I'm using for my Macbook) and the other is a single spdif. The problem is that I have 3 sources (computer, cable and Oppo).
I did a web search and only could only microphone preamps with the digital output and couldn't find one with remote.
Post edited by Ern Dog on
  • littlewoodboats
    littlewoodboats Posts: 823
    Could you connect your cable box through the Oppo?
  • Ern Dog
    No because the Oppo doesn't have any inputs only outputs.
  • Ern Dog
    anonymouse wrote: »
    What you probably should get are two devices:
    - A digital switch to put in front of your DAC. You really do not want to get one with a volume control as you will introduce artifacts into the digital signal upstream of your DAC. Something like this might work: http://www.inday.com/da4x/da4x.htm
    - A remote controlled preamp downstream of your DAC. Too many choices here.
    Considering the amount you have invested in that DAC, you want as little by way of additional components in the path though. So consider if being without a remote is really that big a deal.
    This Inday might do the trick at least for part of the solution.
    I want to avoid anything downstream from the dac for sound quality reasons. It sounds cleaner going direct to amp.
  • Ern Dog
    Another idea is keeping my current preamp (it has volume remote) in place, but then connect it to an analog to digital (spdif) converter. The opposite of a dac. Hmmmmm.......
    tonyb Posts: 33,069
    I think Classe makes one but I don't know about the number of in/outputs. Maybe Peachtree ? Bryston ?
  • brgman
    brgman Posts: 2,859
    There are inexpensive a/d boxes that are made for vinyl ripping.
    I’M OFFENDED!!!!
  • unc2701
    unc2701 Posts: 3,587
    Check out Meridian- they do what I think you're saying you want. Their gear is all digital, so they've got options that you wouldn't normally think exist. The 56* series isn't bad used... (to clarify, you're looking for models with numbers like 561 and 565). Don't worry if you find a used one without their remote- they're really good about pushing out the remote codes to everyone, so my TWC cable box remote would even control them.
    Anyhow, listen to what anonymouse is saying above- doing volume control in the digital domain has its own set of problems. You're probably better off getting a competent pre that also has digital inputs. Musical Fidelity CD Pre would have you covered and then some:
    http://www.musicalfidelity.com/uploads/manuals/English/cdpre_eng.pdf
    Bryston also makes some pre's that you can get DAC boards for, but that's going to be pretty pricey.
    Backburner:Krell KAV-300i
  • steveinaz
    steveinaz Posts: 19,545
    I used an Inday switcher for awhile some time ago--it worked quite well.
  • unc2701
    By the way- nearly all composite video switchers will work with coax digital audio. You won't get volume control or anything, but if all you need to do is switch sources it'll work fine. I actually do this with my B&K CT 610- it does all my audio switching (analog as usual, digital audio on the video I/O), then I have an outboard matrix switcher to do the high-def video.
  • DaveHo
    DaveHo Posts: 3,583
    What about using an optical switcher like this:
    http://www.amazon.com/Recoton-ADS1000-Digital-Selector-Switch/dp/B000034D6G
    Not much risk if you don't like the result.
    -Dave
  • zingo
    zingo Posts: 11,258
    I was going to suggest Meridian as well. Their DSP speakers only accept SPDIF input, so the matching preamp outputs SPDIF with volume control.
  • bikerboy
    bikerboy Posts: 1,230
    Add this to the dac and then you will have 4 spdif inputs.
    http://www.twistedpearaudio.com/digital/cs8416mux.aspx
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • Drenis
    Drenis Posts: 2,871
    Meridian is uber expensive stuff though.
  • unc2701
    Drenis wrote: »
    Older Meridian isn't too bad. The 565 ones on eBay right now are overpriced, but with some patience you can pick one up in the $200 range. There's about 4 models in there that will work. 561, 565, 568 and 518 for sure. Check the manual on the 562. The 518 is probably the most dedicated to the actual task at hand, plus it does some other interesting digital domain manipulations. Nothing amazing by current standards, but pretty solid performer. The others are all preamps with digital pre-outs, so they're going to have other crap you might not need. If you get a 565, look for the DTS symbol on the front or confirmation it's been upgraded to the latest software- the ones with out have much lower resale.
  • Ern Dog
    Thanks for suggestions. Out of everything, I think the Meridian digital processor would fit the bill the best. It has the spdif output and a volume control. Schweeeet! Thanks guys.
  • zingo
    zingo Posts: 11,258
    Meridian electronics are ugly though...
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Can you a digital surround preamp/processor. I use my Marantz av560 for only 2channel it has all of the inputs and outputs you desire.
  • unc2701
    zingo wrote: »
    Yup ugly and the wrong size, too- Narrower than a standard rack, but not narrow enough to put two of them side by side. And every single piece looks exactly the same on the front.
    Here's the link to my FS when I dumped the 518 I had- describes it a little better and has links to reviews:
    www.polkaudio.com/forums/showthread.php?77922-Meridian-518-Digital-Audio-Processor-Pre&highlight=meridian
  • Ern Dog
    zingo wrote: »
    I agree.
  • Amherst
    Amherst Posts: 695
    Used Parasound C2 about $500 you may even wind up running it standalone for the SQ.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • newrival
    newrival Posts: 2,017
    I still don't see why you need an spdif output in a preamp unless it's for a monitor or digital tape loop. It sounds like you either need a DAC with more inputs, a signal switcher, or another DAC. How would an spdif out on a pre solve your problem of too many sources and not enough inputs?
    My Musical Fidelity CD-Pre24 has what you describe, but I just dont see how it would remedy your problem. It's possible I don't understand your situation.
  • newrival
    I suppose another useful purpose could be to route into a digital active crossover in a bi/tri-amp situation.
  • unc2701
    newrival wrote: »
    That's what I was doing with it. Keep everything digital until right before it hits the amp. In this case, I think the OP likes the results of his DAC directly coupled to his amp, thus the need for volume control going into the DAC.
    However, it does occur to me: Does anyone know if the volume control on the Oppo changes the digital out level or just the analog output? Most cable boxes have a setting where you can switch the audio output from fixed to variable, so a simple switcher might still do the trick.
  • Ern Dog
    newrival wrote: »
    With a preamp with a digital output, I could connect my DVD/CD player and cable box to it via digital inputs, then using the spdif ouput on the preamp to connect to the dac. I want the dac connected direct into the amp. This way I can use the remote volume control in the preamp to adjust the volume to the dvd/cd and cable, plus have the added benefit of it going through the dac.
    UNC- I found out the hard way that my Oppo disengages it's volume control feature when the digital output is engaged.
    I just realized a moment ago that I have an older Harmon Kardon AVR 635 w/remote that has been packed away in my closet for a long time and it has everything that I'm looking for. Now I feel stupid because I already have what I've been looking for:lol: I'm going to sleep now and will unpack the HK over the weekend.
  • Ern Dog
    unc2701 wrote: »
    This could be helpful. I didn't notice this feature in my Directv cable box. I forget which HD model it is. Is this setting in the on-screen menu or a physical switch in the back of the box?
  • unc2701
    Software setting. I haven't been on DTV in about 8 years, so I can't help you, but look in the audio settings- it should also have a PCM vs pass-though setting that you'd have to set to PCM for your DAC most likely (otherwise it'll send 5.1 to the DAC which it can't handle).
