Pair of Bridged Hafler DH-200's
Kinda close to Christmas - time to buy. Good luck w/the sale.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Does anyone know of a mono-mod for these amps so they can power 4 ohm speakers?
I havent heard of one but to run 2 ohms the output transisters will fry , as the amp sees the load 4 ohms mono=2 ohms stereo I wouldnt try that on any older amps , if you have to drive a 4 ohm load you would be better off selling the amps amp buying something that is FULLY capabile of running 4 ohm mono .
If you try it you may fry the amps and they are worth nothing than
Does anyone know of a mono-mod for these amps so they can power 4 ohm speakers? -
I decided to give these a try in stereo (non-bridged) configuration, vertically bi-amping one per speaker. With stereo rated specs being 200wpc at 8 ohms and twice that a 4 ohms, these should make interesting quasi-monoblocks on my 8 ohm B&W 804s with additional headroom due to the vertical bi-amping.
Mark these as SOLD!
Thanks Zingo!Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's -
Got the amps in the mail, and they were packed great. Great seller to work with, and would do it again!
