Polk Monitor 10 speaker parts
vstarkwell
I recently picked up a pair of Monitor 10's and the cabs were in very rough shape. The played fine and sound great however they were quite the eye sore. I decided to part them out and have the following for sale:
4 MW6503 6 1/2" drivers (will fit SDA-CRS too), one dust cap pushed in. $20 each
2 SW100 10" passive radiators. $20 each
2 SL 2000 tweeters. $10 each
2 stock crossovers. $15/pair
2 grill covers w/logo pins, clean & scratch free. $15/pair
I also have a pair of Polk Monitor 7 grill covers they are clean, however one of the logo badges is missing: $10/pair
As for shipping I will charge the least amount I can and I'll make sure they are packaged securely and get a shipping quote before I send them.
Note the red arrow, not sure if this affects the tweet as it sounded fine to me
Monitor 7C's With Tubes
Post edited by vstarkwell on
Do they have a fused cups?2 stock crossovers. $15/pair -
Oldfatdogs wrote: »Do they have a fused cups?
I'm not sure what you mean, if you can point out what I should be looking for I'll gladly check for you. Here's a pic of one.
Monitor 7C's With Tubes -
Fused cups on the other side of your picture where speaker wires from amp go to.
Some versions have fuses while others don't.
See this link for fuse on the terminal cup: http://i.ebayimg.com/t/Pair-of-polk-audio-monitor-10B-crossovers-/00/s/OTYwWDEyODA=/$T2eC16JHJIYE9qUcN,h,BQWL8ND37w~~60_57.JPG
If you flip them over is there a spot for a fuse under the posts where speaker wires attach ?Thanks
Dan -
Thanks for the help Mystery.
Thanks Mystery and Oldfatdogs there are no fuse cups just the standard binding posts. Here's a pic
I am interested in the monitor 7 grills...can I get a picture of both sides? Thanks!
vstarkwell wrote: »Thanks Mystery and Oldfatdogs there are no fuse cups just the standard binding posts. Here's a pic
Hehe... we could have figured that out with the blue polyswitch on the first picture with capacitor. :rolleyes:
Polk replaced fuse with polyswitch on later versions.
I don't think both fuse and polyswitch exist together.
Thank you sir,I'm going to pass until I find the proper ones to go with my 10s.
Conradicles wrote: »I am interested in the monitor 7 grills...can I get a picture of both sides? Thanks!
Hey Conradicles,
I got these grill covers from my local vintage guy, he had just parted out a pair of 7's, not sure which model but I'm guessing 7A's as I also bought the peerless tweets he had. I assumed they would fit my 7C's but alas they didn't fit they are too big. I hadn't looked at them in awhile and as I was taking pics I noticed a small hole in lower right had corner a scooch above the hole were the missing log badge would be. Note the red arrows other then that they are clean and unwarped.
These 2 pics are front & back of the one with the logo badge
These 3 are front & back of the one with out logo badge and small hole I mentioned above
Oldfatdogs wrote: »Thank you sir,I'm going to pass until I find the proper ones to go with my 10s.
No problem I hope you find them.Monitor 7C's With Tubes -
Thanks for the pictures! The grill I need is a bit different so I will pass.
Do the Monitor 10 grills attach to the speaker using the velcro patches or dowell/posts?
They attach using the dowell/posts.Monitor 7C's With Tubes -
Thanks for the reply. Unfortunately I have an early pair that uses the velcro.
you check that SL2000? that looks like the voice coil wire is broke, which would mean it's D.O.A.
I listened to it as I noticed that right off the bat and it seemed fine, I did point it out in original post. As for checking it I'm not mechanically inclined so I'm not sure what you mean. I'm not trying to hoodwink anybody If that is a concern I'll gladly delete it from post. I was just trying to share with this forum before I tried CL.Monitor 7C's With Tubes -
If you have a multimeter, you can check resistance values in ohms.vstarkwell wrote: »I listened to it as I noticed that right off the bat and it seemed fine, I did point it out in original post. As for checking it I'm not mechanically inclined so I'm not sure what you mean. I'm not trying to hoodwink anybody If that is a concern I'll gladly delete it from post. I was just trying to share with this forum before I tried CL.
Not mechanically inclined so no multimeter.If you have a multimeter, you can check resistance values in ohms.Monitor 7C's With Tubes -
You are correct sir, just got back from the shop and he took one look at and said junk. My bad I had no idea.Monitor 7C's With Tubes -
To the mods can you please update as sold please,Monitor 7C's With Tubes
