Help - Subwoofer box design
hoosier21
hoosier21 Posts: 4,424
Can somebody here design a subwoofer box for me?
http://www.parts-express.com/pdf/295-190s.pdf
Driver information above.
A pair of subwoofers will be hidden behind a false wall, so box size is somewhat unlimited.
These are to be used in a Home Theater, so deep boom boom is wanted.
Internal volume and port sizing is all I need. Quick and dirty.
Thank you
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
  • 20hz
    20hz Posts: 636
    edited November 2012
    Call parts express they have box programs and can help you .
    Or if you can figure out Win isd its a free box program online .
    There are many variables ...
    How much amp do you have ?
    How big of a room do you have ?
    On the subs I built I found you can go smaller ported box but you need more power and a bass boost , I found going big and sealed sounds by far best . but if size is a problem you can go sealed isoberic its half the size but it takes two drivers the advantage is a small box .
    hoosier21 wrote: »
    Thank you
    Russ
