OPPO Discussion Thread
brgman
A fellow Polkie and new Oppo owner asked if we could set up a thread for Q&A on all things Oppo.
I thought with the new 103/105's coming out there will be many new 83 and 95 owners as well as those of us that upgrade to the new ones.
Please help out with your knowledge on these great players wherever you can.
And ask anything you care to about Oppo operation.
Haters need not apply.:eek:
I’M OFFENDED!!!!
I’M OFFENDED!!!!
Post edited by brgman on
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Cool.We don't have to worry about Face's input anymore.He prefers Google.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Anyone know why Oppo's are advertised as "region free" on AGon etc sometimes for a few hundred bucks more than normal?
I could play PAL and VOD without any problems on the 95 and yet these models are somehow special.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks for the thread brgman. I have the BDP-103
Here is a question, why, when I select two channel does the unit still show the sw cabinet in the set-up and make me select a crossover freq?
I e-mailed Oppo and they said the crossover does not apply when using the analogue outs. It does apply as I can change it and hear the difference. How do I set it for only (full range) two channel?
As always gear does apply. here is what I have
Dish Network Receiver. HDMI out of the Dish unit to the HDMI in for the Oppo. HDMI out of the Oppo to a Samsung plasma. Oppo handling all of the Video chores. (and DAMN! does it handle those chores well)
Audio is out RCA R & L from the Oppo to my GFP-750 to be played in two channel. Adcom amp to my SDA2A's. Signal Cable IC's and speaker cables -
So no SW is connected at all or it's connected but you do not want it showing up when in 2 channel?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
SDA2A's and nothing else. My system has no provision for base cabinets.
I bought the Oppo as it was supposed to be able to combine multi-channel audio. It does and does it well but it clips the bottom. Down mix works as advertised when it comes to movie sound tracks on two channel.
Try it on yours and see if it makes you select 40hz on the crossover. -
I will when it gets here
Sold the 95 and waiting for the 105 to hit the doorMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
You are a stronger man than me. Having now owned a good transport/decent DAC I would never let it go without the new one in the house. I thought the Sony 2000ES changer was alright to get by for a while. Light years better than the Sony DVD player I had been using, right?
I have now seen the light.
This audio stuff is totally cool. Youth may be wasted on the young but the geezers have all the cash. -
I expected a flood of 95's to hit the market once this was released so I just got out in front of it
Can't afford to keep both.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Am I correct in my reasearch that the 105 is the only oppo unit with a digital in so that other devices can take advantage of the dacs?
And would the dac in the 105 best a $500-$700 dac?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I'm waiting to hear some comparisons. The chip they're using is also in $10,000+ DACs, but the chip itself isn't everything...And would the dac in the 105 best a $500-$700 dac?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Is it just me or is the remote and interface painfully slow?Too much **** to list....
Cool, I'll keep my eyes open for that also.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I do not think this is correct. Mine processes both audio and video from the Dish Network receiver. I have also networked my PC through the cat5 connector for audio.
I cannot speak to the quality of the DAC other than to say the audio is much better from the Oppo.
to SDA1C. I liked the interface but have no past experience to compare it to anything. It would be nice if I could assign the default to HDMI in Back on start-up. I liked that it is simple to use and navigate. That said, it also seemed generic and bland but for the crossover question above it seems to work. -
You are 100% correct on that ! The one thing I hate about my 95 is that it's a freaking slug. -
I am obviously missing something here. What are you doing with the unit that the speed of the interface becomes an issue?
Sal was posting at the same time I was. No wonder I did not understand the comments. -
I don't think it's that slow, not compared to the kw SACD player, that is slow and it's not even a BDP..
IMO the oppo line is a great bang for the buck player. One can't go wrong with an 83se, 93, 95, 103, 105.. -
Received my 105, yesterday. Listened to it for a few hours last night and I'm really pleased. I'm running it in stereo w/balanced IC's to an Adcom GFP-750 which is connected via balanced to a Sunfire 300/2 pushing 1.2tl's. First thing I noticed was deeper and more natural bass. Overall, in one word, it's very "smooth". My wife came home from work during the un-boxing and she's not to keen on reference sound levels, so I've had to keep the volume down. More critical listening to come after Thanksgiving.
Other thoughts...I've played 3 CD's and several hours of background music from a Synology DS211 NAS. Setting up wireless was a breeze and I've had a good connection between my router, on the 2nd floor, and the Oppo on the 1st floor. Browsing via DLNA is going to be a pain. I have 1000+ CD's ripped to the server and the folder interface is slow. Paging down to the appropriate artist/band takes a while. Oppo has Media Controller software for the BDP-9X line, but it's not compatible w/the 103 or 105. Their Facebook page says they're working on porting it but don't have a release date. I like the Squeezbox server app but Oppo doesn't have anything like it. Oppo's recommendation is to use a third party app like BubbleUPnP w/Bubble's server. Unfortunately, the Bubble server requires Java loaded to the NAS and what little research I've done, looks like it'll be a bitty to do on the DS211. Doable, but I need more time to figure it out. The Squeezebox server is supported by Synology and was fairly easy to set up when I went to a NAS.
Late last night I connected the HDMI output from my Xfinity DVR to the 105. I ended up w/the same HDMI syncing issues many user's have reported. Watched it for a few minutes and then swapped the cables back to the original config. I'm really interested in using the Oppo in place of my Sunfire TGP-III A/V processor and the Adcom GFP-750. I'd move the 750 to my bedroom rig and sell the TGP-III. This would really simplify my connections and eliminate additional components in the sound chain. More to come on this.
The remote works good but the Android app is most definitely faster. The new beta firmware is reported to improve DLNA browsing, possible sluggish remote commands and some of the syncing problems. I'll hold off on loading the beta release until it's officially released. For those that want to try it...you can fall back to the previous release if it isn't stable.
I'm sure most of you have searched the web for all things BDP-103/105 related, but just in case you've not, the following are good reads:
http://www.avsforum.com/t/1439524/official-oppo-bdp-105-owners-thread
http://www.diyaudio.com/forums/digital-source/222596-oppo-s-bdp105-discussions-upgrading-mods.html
I can't wait to get more alone-time w/the player but so far, I'm impressed w/the SQ, build and potential to simplify my setup. I'm not disappointed in this purchase. Off to help w/Thanksgiving...Happy Thanksgiving to CP and for anyone interested, here's BDP-105 un-boxing ****:
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I haven't been overly impressed with my 95 and will likely be getting rid of it in the near future.
littlewoodboats wrote: »I am obviously missing something here. What are you doing with the unit that the speed of the interface becomes an issue?
It doesn't matter what I do, it's just plain slow - kind of crappy for a 1K player. -
Show me a player that loads a BluRay fast.. If it doesn't load lightning fast its crappy?? Cambridge BDP is in line with OPPO and doesn't load any faster..
Also are you in that big of a hurry to watch a movie? When it's playing its not like its playing at slow speed.. LOL!!
Remember the days of VHS?? That was crappy!!
Just bustin your chops my man but I doubt you will find anything better in that price range.. -
What have you found that performs better?
I may want to look into it.
If i can spend 1k and get an even better Universal Disc Player i'm all ears.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Want mine?
J/K... I purchased my 95 back in February of this year. At first it was absolutely fantastic. I had it hooked up via analog cables and the sound was incredible. That was up until I installed the firmware updates OPPO likes to push. The first time I ran the firmware update everything went to hell in a hand basket. The operation (start up, changing chapters etc...) is now at a snails pace and the player often hangs in the middle of a movie (Blu-Ray) and I have to start the movie over (this happens about 3 out of every 10 movies I watch). Not sure if I got a dud or what but I'm definitely not impressed. Spending 1K on a player is a good chunk of change. I guess I expected more for my money. @ brgman - yes I have found a better player (not for SACD) - my cheap **** Sony is what I have hooked up right now - at least I can watch an entire movie without it cutting out on me. I am currently deployed overseas (AF) and the first thing I plan on doing when I get home is to send my player to OPPO to get it checked.
Did you try reinstalling the firmware? If it was working to your satisfaction prior to the update but not after then the update certainly seems suspect. From the reading I have done I do not think yours is a common complaint. Have you talked with Oppo and if so what was their reaction?
Good luck getting it sorted -
I will try reinstalling the firmware when I get home next month - hopefully it will fix the problems because I really do like the 95 when it's working properly.
I have the 93, upgraded from the 83, and thinking of getting the 103. I only use my Oppos for HT. Anyway, I know this is a stupid question, but I did not see anything in the manual about it. One thing I loved about DVDs, and hate many BRs for not supporting it, is the resume on play feature. This is where the next time you play the movie it resumes from where you stopped. It drives me crazy many BRs do not support this.
Anyway, people say use the bookmark option. Okay, but I cannot figure out how to bookmark a movie, and it is not in the manual. Is this easy on the Oppo?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I am not sure I completely understand your question but will give this a shot. I have started a BlueRay, had friends stop by so shut off. Come back hours later and things pick up where they left off.
Is this what you had in mind?
Has anyone who ordered the 103 tried the analogue outs? I am wondering if the crossover point shows up when doing two channel only?
