PSW250 woofer-not working
polkguy
polkguy Posts: 4
edited May 2004 in Flea Market
Is this worth anything?
the cone appears to fine.
if you hold it from the magnet it wobbles.
sounds bad.
ken hooked me up with a new one and all is well.
just the woofer - not box or amp.
    VR3 Posts: 29,427
    edited May 2004
    If you have a desk job...
    a paper weight...
    If you need something to hang on the wall...like to cover up a hole in case you got mad and punched the wall...
    You can hang it on the wall
    otherwise...it is worth a trash bag...and garbage day pick up
