Rubber feet for DreadNought (AI-1)
Drenis
So I bought some rubber feet off ebay for my DreadNought case but they are way too small to use. The feet size is okay but the hardware wont secure properly due to its size.
What have you guys who have these used? Any good recommendations?
Post edited by Drenis on
You're using one of Larry's cases? He has pre drilled threaded holes for spikes.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Speaking of which, I should email AL and get an eta on our transformersGood music, a good source, and good power can make SDA's sing. Tubes make them dance.
Yes. I didn't know they were specifically drilled for spike use. They aren't threaded.
However, this thread is of no use now because when the question was put to the other half, lets just say the case will be standing on its face behind the TV stand. No feet needed now. I should have just asked her to begin with.
