Recap and bass is gone?
gmjungbluth
gmjungbluth Posts: 232
edited November 2012 in DIY, Mods & Tweaks
Hi all,
This isn't a Polk question per se but I've gotten so much great help from this forum that I thought I'd try here before signing in somewhere else...
I recapped an old old pair of Sony speakers (SS-580) for a neighbor not long ago - these are little 3-ways in nice wood cabinets - look like mini KLH or ARs of the late 1960s. When I got them they had no sound coming from the tweeters. After replacing the caps in both crossovers (one 1uf and one 2uf), they both have great soaring high notes but almost no bass - low notes are completely lost.
Now these are not heavy duty speakers or woofers, but I do seem to remember that they reached at least a little bit lower before. Could the recap have changed the crossover values? I used the same value capacitors. And both speakers sound the same so I didn't short anything out.
Thanks for any insight you may be able to provide,
HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
Post edited by gmjungbluth on
  • sda2mike
    sda2mike Posts: 3,131
    they need burn in time...with my 2b's, it was abt 100 hrs for the low stuff..at about 200, it went away again...then everything bloomed! birds chirped and the sun shined always, it was magic:)
    seriously, just give em time
    As I understand it, recaps usually do not have such a radical effect on bass. If you have an extra mid or bass speaker of similar value perhaps you should hook it up to the speaker and see if it plays some more bass?
    All the vintage speakers I've ever heard that have working woofers have "always" put out bass, it's the mid/high that the old crossovers filter out or won't let through!
    cnh
    F1nut Posts: 51,953
    Those are the only caps on the crossovers?
    Are the speakers sealed or ported?
    Most folks notice an improvement in the bass response right out of the gate. Your experience is not the norm.
  • sda2mike
    i had bass...it was flat, though....to the o.p., you don't have many parts to replace..check and recheck everything..
    good luck
  • CoolJazz
    CoolJazz Posts: 572
    Two possibilities come to mind....if you're talking about beyond break-in....
    -Did you read the original cap value markings correctly?
    -Maybe you filipped phase on wires going to a driver in one cabinet. Try running just one of the speakers and see if the bass comes back. Also might listen to each cabinet one at a time and make sure they both sound the same.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • gmjungbluth
    Thanks all for the posts. I'm thinking that I must have read the cap values incorrectly, at least one that is going to the woofer. All speakers put out sound.
    I don't think it's a phase issue either, but I will check speakers one by one.
    HT System:
    Marantz NR-1403
    Front: Klipsch CF-4
    2Ch:
    Living Room:
    Harman Kardon 3380
    Bedroom:
    Polk PSW10
    KLH Model 6,
    Polk LSI7
    NAD 7100
    pitdogg2 Posts: 27,236
    hopefully you still have the old parts to double check as those values seem too low to me.
