Small cheap 2 channel amp to power outdoor speakers
warlocks1
I need a small 2 channel amp for my deck speakers. I will will be using a Denon receiver zone 2 preouts. I don't have much room in the rack so I am looking for something thin. I don't need much power, it will be used a low levels for background music.
Condition is not important.
Thanks, Jeff
Thanks, Jeff
Post edited by warlocks1 on
If nobody on here is selling something that fits the bill, you could look for a used Parasoun Zamp. There are a couple on eBay right now.
I'd look at parts express, they have some smallish, cheepish amps.
I have an extra one of these I can send you. Decent amount of power and actually sounds good! PM me your address if you want it.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-383Vinyl, the final frontier...
There is the Carver TFM 6cb. Real skinny and rack mountable I believeHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
... or... if you are as parsimonious... nay... as cheap... as I... you might consider this:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=310-300
It's small.
It's cheap.
It sounds good. Surprisingly good. Borderline stunningly good (particularly for twenty smackers).
It is my current de facto test amp. In the photo above it's testin' a Technics cassette deck as found from my favorite local vintage hifi emporium ;-) -
I think thats the one I was referring too. ^^^
I have a csi p-30a PA amplifier I believe could be used. Really cheap as I have no use for it.
http://www.starkelectronic.com/spc294.htm
PM if you are at all interested. -
If really on the cheap, look at the SMSL Class-T (Tripath) amps. I picked up an SMSL SA-1 which uses the TA-2020 and is rated for 20W into 4 ohms. I was amazed how nicely it could drive the Polk S8's even outdoors.
http://www.ebay.com/itm/Upgrade-SMSL-SA-S1-TA2020-High-grade-HIFI-Digital-Power-Amplifier-B-/290749523878?pt=US_Home_Audio_Amplifiers_Preamps&hash=item43b205a7a6Stan
Main 2ch:
HT:
Other stuff:
I had no idea about the T amps. I have a PM into Madmax. Thanks for all the great suggestions.
The Tripath chipset amps (even the really cheap ones) tend to exhibit smooth, liquid midrange that is almost annoyingly evocative :-) of the sound of a far more expensive single-ended amplifier using a directly heated triode (e.g., 2A3) output. The little cheap-jack one I posted above sounds more like my SE 2A3 than I'd have believed without hearing both myself on my Duplexes. The T-amp has somewhat more extensive but also somewhat more aggressive HF than the SE 2A3 amp (at a ca. 50-fold cost differential).
I bought a cheap new open cage amp $5 I am driving it with a old computer power suppley , it works great its on my test bench driving some little optimus 3.5" speakers gets plenty loudI had no idea about the T amps. I have a PM into Madmax. Thanks for all the great suggestions.
I picked up a little class T amp off ebay (SMSL SA-S1 TA2020) rated 20 watts / ch. This thing sounds way better than it has any right to for about $35. The build quality is excellent and uses very good quality components. My son is using it to drive the Polk S8's and does so with good authority and decent detail. It does lack some of the transparency of better quality amps.Stan
Main 2ch:
HT:
Other stuff:
+1. I have one of those Lepais. A great little amp. I would say ideal for near-field listening. Would be great for outdoor setups too - small, easy to bring in and out, and not a catastrophe if it gets wet and bails!mhardy6647 wrote: »... or... if you are as parsimonious... nay... as cheap... as I... you might consider this:
It's small.
It's cheap.
It is my current de facto test amp. In the photo above it's testin' a Technics cassette deck as found from my favorite local vintage hifi emporium ;-)HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
