In Wall Speaker
Hi All,
I will be building a wall for my in wall speakers.
The wall will be constructed using plywood.
I have read on the manual:
For additional acoustic performance install some insulation into the wall
cavity (be sure to place the same amount behind each speaker).
My Question: Since I'm building this wall now, will it be better if I construct a box right behind the in wall speaker than fill it up with insulation.
Regards
Colin
Regards
Colin
Post edited by ck77 on
Build the in-wall box ( build the correct size box for the speakers you want to use ) and then install the speakers. In one speaker put some insulations and dont put any insulation in the other speaker. Give them a test run and pick the sound you like better.B&W CM9Classé Sigma
