Odyssey Candela Pre-Amp
robert p
I am thinking of buying an Odyssey Candela Tube Pre-amp anyone have any experience with these.
Post edited by robert p on
Owned it, loved it, would buy again
Klaus is great to work with- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My main pre is a Candela - wouldn't trade it for nothing. running 7316 tubes in it.
never had an issue and Klaus is wonderful - you just got to catch him!Aaron
Enabler Extraordinaire -
I have a Candela in my two channel rig, running Amperex 7316 tubes powering a Odyssey Stratos Dual Mono. It's a great pre amp. As others have stated Odyssey is very good to work with. And with a 20 year warranty, hard to go wrong.
Another thing I like about Odyssey is they have a philosophy of continual product improvement. You can have your Odyssey gear upgraded as improvements are made available.
And finally, their stuff is made in Indianapolis."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
