Crutchfield 1st time buyer
simm
I am considering ordering from Crutchfield a Denon 3805 and an el cheapo DVD player for the bedroom to take advantage of their 10% off sale. I think they have a $20.00 off code for 1st time buyers that are refered to them. Does anyone know if this is true and if it would apply to the 10% off sale as well and finally if it does and someone has a referrral code let me know and if I do order I will use it so you can get the gift certificate or whatever it is they give. Thanks.....
Steve
Steve
Post edited by simm on
Yes, it is true that you get a discount. I would call them directly in order to get this discount, as the website only allows one code per transaction.
Codes: http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=18031&highlight=crutchfieldCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Okay, here you go. My referral code is; 817214. You get $20.00 off and I get a $20.00 credit for my next order.
Let me know if you used it.
Thanks,
Bill -
Bill- There is a thread for this function, which is mentioned above. It would be Polkie of you to add your code to the thread, rather than jump the Polkies prior to you. Your code will get used eventually, no doubt.
The Crutchfield protocol and guidelines are also covered in that thread.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Sorry, I didn't see your reply as I hit the reply button and had to look for the catalog. I even called Crutchfield to make sure that I had my code right. I also did not know about the other thread.
I did look at it after my reply was posted. Again, sorry.
Bill -
I didn't know about the ongoing thread. I will us the next one in line if I do place an order and will post there that I did it. Thanks again.....
Bill - That's cool, thank you for posting the effort. The crew will hit that code soon enough, don't worry
