Analog care accessories
strider
Next up on the block are some essential analog care accesories.
First is a Hunt E.D.A. Mark 6 carbon fiber record brush
Second is an Onzow Zerodust stylus cleaner
Third is a Mobile Fidelity record brush
Fourth is an Ultra Steam Shark steam cleaner.
All are in gently used and perfectly serviceable condition. The Hunt brush I used for dry cleaaning of records that were already run through the RCM. The Mobile Fidelity brush was used for wet cleaning after an initial pre-wash with deionized water. The actual cleaning material on the brush is replaceable, and was replaced recently. The Onzow is a stylus cleaner, very gentle on the stylus material, top of the protective case doubles as a low power magnifying glass to see the stylus' condition. The Ultra Shark was really fundamental in the record cleaning process, after the pre-rinse with deionized water I'd spread the cleaning solution on with a foam paint brush. A quick scrub with the MoFi brush, then a blast with the steam to completely remove the debris from the grooves. After that, a round on the RCM, followed by another steam and RCM cycle. The Ultra Steam Shark is not a current model and didn't find any links on a quick Google search. It's a handheld steamer with a 3 foot cord connecting the steamer body to the nozzle. Would like to sell these as a package if I could, I think $75 shipped in the CONUS is a very fair price.
Wristwatch--->Crisco
Post edited by strider on
I'll take it.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Thanks, Ed. You have a PM to sort out the particulars.
BenWristwatch--->Crisco -
