WTB - Stereo PRE AMP.
PaulyPauly Posts: 4,521
edited May 2004 in Wanted (WTB) Classifieds
Would preffer Adcom but open to other stuff, has to have AM/FM lets see what you got
Spaz
Life without music would
Post edited by Pauly on
  • tonyv1tonyv1 Posts: 365
    edited May 2004
    Check out the Anthem TLP-1 . This should satsify your requirements.
  • PaulyPauly Posts: 4,521
    edited May 2004
    Nice, thanks but something used at an afforadable rate :)
  • faster100faster100 Posts: 6,247
    edited May 2004
    Not bad paul , $699.00 :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    edited May 2004
    LOL. yeah for a pre..not bad. Anyone wanna loan me the 699.00 for a year or so..:)
  • steveinazsteveinaz Posts: 19,003
    edited May 2004
    Spastic--
    the only thing that "scared" me off of the Adcoms w/tuner was the listings on ebay I was seeing that had "preamp section works great, but tuner quit working." I'd wager that 40% of the Adcoms I saw had this comment. I don't know, maybe they've ironed-out the problems on later equipment. That was enough to keep me from going Adcom w/tuner.
    edited May 2004
    yeah faster pointed that out to me and have noticed that. Doesnt have to be Adcom but is preffered. Can always get a tuner rack if it were to go out. :)
    edited May 2004
    I just got a adcom with tuner, and alas the tuner worked, then didn't, then did.. now its doesnt work at all.. all in a short time since i just got it.. But the pre works great... its a 500II model pre-amp,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaNRuSsMaN Posts: 17,995
    edited May 2004
    Forget Adcom active preamps altogether.
    Get THIS and add a tuner to fit your budget.
    Separates man, separates. A tuner REALLY needs its own power supply, and to be isolated from the amp / pre power supply.
    Go passive, and you'll never go back to a sand preamp again.
    Cheers,
    Russ
    edited May 2004
    Russ you got a turner to go with that?
    edited May 2004
    I've ALWAYS got tunas, don't worry about that.
    Cheers,
    Russ
    edited May 2004
    i might hit you up...working on a deal with a mbr and will need a tuna :)
    edited May 2004
    Paul, i was actually looking at this pre- the other day, but didnt really know what it was... Its a non powered pre i guess, passive... cool.. will you lose any volume from useing a passive compared to a regular pre-amp?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
Howdy, Stranger!
