Denon AVR-1713 with Polk Audio Speakers
rodelperezph
rodelperezph Posts: 14
edited October 2012 in Electronics
hi, guys! i'm new here and i'd like to ask for your opinion regarding this 5.1 ht setup.
i'm planning to buy this:
Denon AVR-1713
Polk Audio TSi 200 - front
Polk Audio OWM3 - rear
Polk Audio CS 10 - center
Polk Audio PSW 110 - subwoofer
what can you say, guys? is this setup ok or compatible with each other?
thanks in advance!
Denon AVR-1713
Polk Audio TSi200
Polk Audio CS10
Polk Audio OWM3
Polk Audio PSW110
Samsung 32" LED TV
WDTVLiveHub
Post edited by rodelperezph on
  • rodelperezph
    edited October 2012
    help please...
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
    F1nut Posts: 51,713
    edited October 2012
    Polk has a suggested list here, http://www.polkaudio.com/products/tsi200
    Click on Recommended Products.
    tonyb Posts: 33,069
    edited October 2012
    How big is your room ?
  • rodelperezph
    edited October 2012
    4 x 4 meters...
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
  • specd_out
    specd_out Posts: 505
    edited October 2012
    Looks like a pretty decent setup. Not the OMG gonna blow you a way, but its a solid budget system. Apart from the rear speakers (which dont matter much anyway), everything seems matched well.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • rodelperezph
    edited October 2012
    specd_out - thanks for your comment!
    any other comments out there?
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
    edited October 2012
    Welcome to Club Polk!
    I wouldn't worry about the OWMs in the back, they are designed to be compatible with a number of other Polk speakers and should match up well enough with the TSI series. The only thing we usually recommend is going bigger on the center speaker, maybe the CS20--simply because so "much" of the surround soundtrack is carried by the center channel.
    The entry level Denon should power that setup fine. Set your LFE crossover to 80 hz and enjoy.
    In general, Denon AVRs sound pretty good with Polk speakers. I've run TSIs, RTiAs, and LSis on them and they match up well.
    cnh
    tonyb Posts: 33,069
    edited October 2012
    I'll agree with moving that center up a notch to the CS20, but also If budget allows, look for a psw505 sub, and move the fronts up a notch too to the TSI300, or 400'S.
  • rodelperezph
    edited October 2012
    hi guys! got my denon avr-1713, tsi200 and psw110 and it sounds good!
    i don't have cs10 and owm3 yet... you think i have to go with cs20?
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
    edited October 2012
    If you have the "space" for it you won't regret having the larger center. If not you can get by with the 10. For me there was no question that the larger center was a better choice.
    cnh
  • rodelperezph
    edited October 2012
    ok... maybe i'll go with cs20 next time... and will still go with owm3... :biggrin:
    Denon AVR-1713
    Polk Audio TSi200
    Polk Audio CS10
    Polk Audio OWM3
    Polk Audio PSW110
    Samsung 32" LED TV
    WDTVLiveHub
