Momo MM6 in a Jetta?
I have heard great things abou the Momo MM6s and have been looking into buying a couple sets for my '99 Jetta (new body style) and was wondering if they would fit. Also, any info on what size components actually do fit the new Jettas would be greatly appreciated. I've heard many different answers and am utterly confused.
Post edited by tien0006 on
Welcome to Club Polk,
You will get more responses if you post in the car audio forum at the bottom of the main page http://clubpolk.polkaudio.com/forum/forumdisplay.php?s=&forumid=5Graham -
http://www.mcmaster.com/param/asp/psearch.asp?FAM=plastics&FT_101=523&FT_1340=53162&FT_1215=46258&FT_518=51526&FT_128=521&session=plastics,101=523,1340=53162,1215=46258,518=51526;128=521
Assuming the link isn't cache, here's thicknesses of up to 1.5" of ABS. Problem is, it get's expensive for a 12"x12" sheet (over $50! ouch!).
I say use MDF if you have enough depth between the current mounting area and the door skin and for the excursion of the speaker. Lots of measuring
Brian Knauss
ex-Electrical Engineer for Polk
