Very Nice NAD 7155 55 w/ch high current receiver
geppy1
For sale a very nice NAD 7155 receiver. This model was made by NAD between 1985-87. It features 55 watts per channel with 3 db of headroom and the abiltiy to put out way more power/current into low impedence loads. It even has an impedence selection switch to optimize the power supply. Has a record out selector, inputs for Phono (MM or MC), CD, Tuner, Tape 1 and Tape 2 and can handle two sets of speakers. . Also preamp out and main amp in terminals to allow one to use a larger power amp or bridge this unit and use it with the NAD 2155 power for biamping. Other features include mode switch, loudness, low filter , bass EQ and -20 db muting.
The AM/FM tuner is the outstanding Shotz tuner which is one of the best tuners ever put in a reciever.
The receiver is in very nice shape and everything works as it should. It needs nothing. The front panel is clean with the bottom left corner having a very very slight ding on the very edge.as. The rest of the case is very nice with a slight discoloration on the top left.. The original power cord has been reattached as I use a detachable cord with my gear. Asking $165 or BO Thanks,KG
Post edited by geppy1 on
Had one of these for a while (another Polk Forum denizen has it now); this is a very nice piece of hardware with some cool features (the NAD 'soft clipping' which can be switched on or off, variable phono loading, MM and MC compatibility, etc.)
Excellent receiver! Sounds much bigger then 55 WPC I used to have one. The phono pre is also way better than people would think.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Bump
