Center channel with LSi-15s if LSi-C ultimately unavailable
brentba
brentba Posts: 28
edited November 2012 in Speakers
I'm waiting for delivery of a pair of LSi-15s (as many of you know). For now, I will be digging an Infinity alpha center channel speaker out of the closet that I've had for about 10 years to use for movies, etc. Ideally, I'd like to pick up an LSi-C on the used market, but I've not yet seen any up for sale.
If I am ultimately unable to get my hands on an LSi-C, does anyone have any other recommendations for a center channel that will mix well the LSi-15s for multichannel audio. I'm assuming if I'm patient, I will be able to find an LSi-C up for sale somewhere (especially as die-hard Polk fans begin upgrading to the LSi-M series), but I'm looking for other options, just in case I ultimately cannot find one.
I'm wondering if the new LSiM center channel will be my best option.
And before you ask, I will definitely wait until I have an external amp before adding another LSi to the mix.
Thanks.
Post edited by brentba on
    EndersShadow Posts: 17,687
    edited July 2012
    Be patient and wait for the LSiC. The new LSiM center wont match well since its voiced differently and also a 8ohm load. There are some out there that will pop up eventually
  • sponger
    sponger Posts: 325
    edited July 2012
    So on which amp did you end up deciding? Emotiva?
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • brentba
    brentba Posts: 28
    edited July 2012
    sponger wrote: »
    Haven't decided yet
    The Emotiva XPA-3 looks interesting. Certainly plenty of power to spare and will allow me to add the center channel without buying another amp. I've read a lot of reviews on the Emotiva amps -- from what I've gathered they are fairly strong performers overall, but seem to fall a little short in the mid-high range and may not provide quite as much of a 3D sound-stage as some higher end amplifiers. Mid range transparency and soundstage/imaging is something that is important to me (more so than strong bass performance--where the Emotiva reportedly excels) so I'll probably continue to search the used market for some "higher-end" amps as well.
    Can anyone share their experience with Emotiva paired with the LSi series? Does Emotiva allow the LSi to show it strengths in mid range transparency and imaging?
  • VTO888
    VTO888 Posts: 72
    edited July 2012
    What are you going to run them with in the beginning? Or what avr do you have now? I am a EMO/LSi owner.
  • brentba
    brentba Posts: 28
    edited July 2012
    VTO888 wrote: »
    I'm going to run them with a Yamaha RX-V867 (carefully) in the beginning while shopping for an amp. Have you been satisfied with the Emo/LSi combination?
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2012
    I upgraded my LSiC to a PSB Synchrony One center. It blended in just fine with the front LSi15s.
  • Subdusted
    Subdusted Posts: 30
    edited October 2012
    I have the same problem, however, I will be buying an LSIM center. It may not perfectly match the LSi 15s but.. it's a better speaker than LSIC and the clarity of the dialogue is what's most important.. and, I don't think they are THAT different for it to be an issue. Plus, it's next to impossible to find a new LSIC and used is.. it's just used. And the LSIM will be brand spanking new.
  • Subdusted
    Subdusted Posts: 30
    edited October 2012
    as for the 4-8 Ohm thing... I don't believe in it anymore... I've seen so many so-called 8 Ohm speakers dip down to 3 and sometimes even lower than 3 Ohms that it's just another ridiculous marketing statement.
  • Monster Jam
    Monster Jam Posts: 919
    edited October 2012
    As an alternative, you could run two LSi7s or LSi9s in lieu of an LSiC.
    I've been considering this idea...
    Do you hear that buzzing noise? :confused:
  • ALWALLER
    ALWALLER Posts: 40
    edited October 2012
    Are the PSB Synchrony One center-- 1650 dollars?
    Equipment
    Panasonic TC-P54S2 Plasma
    Scientific Atlanta DVR
    ONKYO TX-SR705 AVR Pre/Pro
    Outlaw 7125 7 CH Power Amplifier
    Toshiba A2 HD-DVd
    Panasonic BD-30
    Harmony 550 remote control
    LSi9 ( Mains )
    LSiC ( Center )
    PSB Ambient 2 Dipoles
    SVS 20-39 PCI Subwoofer
  • Drapolas
    Drapolas Posts: 12
    I am looking for an LSiC Center Channel for my new setup: there are some occasional ones on eBay, but the last one that surfaced was not in good condition. I decided to take the plunge and go with the previous LSi Series. I have just received a pair of LSi15s (which sound great), and liked them so much that I placed an order for a pair of LSiF/X and LSi7s. Do you think I could use 2 LSi7s in lieu of the LSiC. Would you recommend hooking them up in series to my amplifier (if the LSi7s are rated at 4 ohm the combined impedance will be 8 ohms). Any thoughts and insights will be appreciated. Is it safe to wire the LSi7s in series? Anyone tried this configuration? Thank you!
  • angelsfann02
    angelsfann02 Posts: 589
    I have experience with the Lsi-c, Lsi-15's and Emotiva xpa-5. I absolutely loved that set-up. I ran different amp like Parasound and Adcom, but always went back to the Emo. As for the Lsi-c, while it is the designed center for any Polk Lsi system, I always found it to be lacking. Never clear enough for me, never dynamic enough for me. I really disliked the cascading crossover. I felt the Lsic was lacking something. I always wanted to do the crossover mod that so many others have done, but never got around to it.
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
