Amp suggestions?
BlakeAwos
Hey guys, I got two dxi 124dvc's and I want to use both in one box, but I don't know what kind of amp to get:rolleyes: I don't know that much about Amps and what to run but I want something that I can get a big amount of power out of. Any help is appreciated!
Post edited by BlakeAwos on
This should work. 1000 watts at 8 ohms. You will need two of them since they are mono blocks.
http://bryston.com/products/power_amps/28BSST-2.htmlLumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
You may want to try Polk or Crutchfield customer service. I'm sure they could assist you.
I sent me an email last night and thanks, ill look into it!
Would that be the same as 500 watts at 4 ohms or not? -
yea the brystons nice but way to rich for my blood !
Find out how much power you need for the subs than Try a used prosound amp I suggest a QSC GX5 or a gx7 the gx5 is $400 new at parts express it does 500 watts at 8 ohms , you can always try used or a gx7 if you need more power . -
crown k2?
O audio plate amp?
