Plumbers advice: clanking sink pipes?
Erik Tracy
Any CP Plumbers got some advice?
Our upstairs sink in the master bedroom has developed 'clanking' noises when the water is turned on.
Is that a sign there is air in the pipes? If so, is there a DIY solution, or do I need to call a plumber?
Thanks,
Erik
Thanks,
Erik
Post edited by Erik Tracy on
My first thought would be to look for a broken (maybe rusted) pipe mount. :cool:
Pipes leading to faucet are loosely mounted somewhere.
My first thought would be to look for a broken (maybe rusted) pipe mount. :cool:Pipes leading to faucet are loosely mounted somewhere.
yep my first step -
Agreed ^^^^
Or....sounds like a case of you just needing to get your pipes cleaned. Yuk Yuk !!
lsi 9's -
It's called "hammering". You can add an inverted air chamber to in effect, cushion the sudden starting and stopping of the water.
http://www.google.com/search?num=10&hl=en&site=imghp&tbm=isch&source=hp&biw=1280&bih=620&q=anti+hammering+device&oq=anti+hammer&gs_l=img.1.2.0j0i24l7j0i5i24l2.1611.6183.0.10482.11.11.0.0.0.0.97.813.11.11.0.cfrsh..0.0...1.1._G-MQ4TuSl0#hl=en&site=imghp&tbm=isch&sa=1&q=plumbing+anti+hammering+device&oq=plumbing+anti+hammering+device&gs_l=img.12...15205.19759.0.22190.9.9.0.0.0.0.50.354.9.9.0.cfrsh..0.0...1.1.JNAjAit8WiI&bav=on.2,or.r_gc.r_pw.r_qf.&fp=834cc335a8e994da&bpcl=35277026&biw=1280&bih=620 -
Be sure to get one construced of oxygen free, audiophile grade copper !!!!:twisted:
Hot or cold water or both.
Hello, Eric. There are two things you can do yourself. Make sure your water pressure isn't too high and since you had mentioned that it has been developing, check or replace the valves at the fixture. Many times, just doing this will solve the noise issue. Regardless, try not to use that faucet anymore until it is repaired unless you can handle a possible and unexpected "uh-oh".
Newer or real old construction? If newer, and copper tubing, they should have installed air cushions or "bumpers" in the supply lines in the wall near the sink. (Pops called them bumpers anyway, first learned of them back in the mid '60's helping him plumb new houses). This would consist of a T fitting in supply line, elbow and short piece of capped pipe alongside the supply line. IF the air has been forced out of the bumpers, you can shut the water off, drain lines on lower floor (or outside sillcock) and slowly turn water back on to get that air cushion back in the bumper.
If copper water lines, plumbers usually flatten a piece of copper tubing at the ends and wedge it between two studs. Then they solder the hot and cold water pipes to it. If they didn't clean the pipes properly or solder it well, sometimes they break free and the pipe(s) will move when water is turned on and off. IF that happened, obviously you have to get into the wall to fix it.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
This started happening 6 months or so after a remodel of our master bathroom. I wanted a re-circulating valve put in between the hot & cold since the master shower was in the upper/opposite location of the my 2-story house in relation to the gas water heater in the garage.
Thing is - the recirculating valve is installed on the 'his'(my) sink and the clanking is on the 'hers' side of the two sink master bath.
My wife's sink will clank if the hot OR cold is turned on....whether fast or really really slow, but my sink is totally fine.
Sounds like a valid, contractor call back to me.......
Duly noted...I've got the plumber's card....call in-coming....
Mine bang too... all new plumbing and they cant secure anything right. Good ol 100+ year old home.
I don't think it's water hammer, that usually happens at the start and stop. Scomp has that covered. Sounds like a support issue. Call your plumber back in...
Erik Tracy wrote: »
Ahhh, the real reason for this thread, the clanking is on "her" side. I'll bet if it were up to you it wouldn't be that big a deal. Certainly sounds like you need to call the contractor back. Cheers. :cool: -
I tried turning on the hot and cold taps one at a time really slow to see if the clanking was a pressure 'thing'.
When I turned on the hot - about half way on, the hot water momentarily stopped coming out, then the clanking started, then water started coming out again.....
Gotta find the contractor's card....
That's your recirc valve. It's slamming closed and causing some hammering. 3 things will need to addressed:
1) obviously, the recirc needs attention.
2) you need some hammer arrestors installed. ( see SComp's post, but they do have ready units)
3) the pipes need to be secured around the recirc valve.
