is this worth it ???
QX300SA Subwoofer
12" polypropylene woofer
300 watt digital BASH amp
Phase control
Variable crossover control
22Hz to 150Hz flat
Stereo line level inputs
LFE input for Dolby Digital & DTS
Volume control on front panel
Brass cone feet
15.35"H by 15.35"W by 17.72"D
2.09 CUF internal volume
Weight 53lbs.
$949.00
Factory Seconds $599.99!!!
Phase control
22Hz to 150Hz flat
Brass cone feet
Weight 53lbs.
$949.00
Post edited by Willow on
You know what we're gonna say....SVS 25-31PCi...$549 (everyday).Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
thats CAD price
Personally, I dont trust the new Dahlquist. Also, look at the wimpy basket with 4 screws?
http://www.audioshop.on.ca/dahlquistsubs.htm
For a little more money you could get this Shiva kit from CSS.
SUB
http://www.creativesound.ca/details.php?model=EZTUBESHIVAP
AMP
http://www.creativesound.ca/details.php?model=SUB250R
Or check out some of the Paradigm subs, the PW2100 is not a lot more money.Graham -
thats where they have it are you in Otown ???
No, Toronto. I havent been to any good audio shops in Ottawa. Do you know of any?Graham
we only have Dewars on Merivale they are big on B&W and the audio shop and maybe sound advice across from Dewars mostly paradigm
im having a hard time finding a good sub in Ottawa -
Looks like a great deal. Go for it and let us know how it sounds.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Specifications:
● Driver: One 12" Long-throw Woofer
● Amplifier Power: 325 Watts RMS; 1300W peak
● Frequency Response: 25 Hz - 180 Hz ± 2 dB
● Dimensions: 21.75" H x 15.0" W x 22.0" D
● Weight: 58 Pounds
● MSRP: $579 (2 for $999)
Outlaw Audio
www.outlawaudio.com -
I think that Outlaw is a clone of the HSU VTF3,
Here is a link for a Canadian HSU dealer
http://www.hi-fidelity.com/DVDCases.htmGraham -
have you ordered from them before ???...Im lookinf at the 8 or 10 stf1 or 2
I haven't. I built my own sub, but a few people over at the Axiom forum ordered from them without a problem. I think you should consider saving up for a stf3.
Our resident sub-ologist doc spec did a comparison with the STF3 here:
http://www.hometheaterforum.com/htforum/showthread.php?s=&threadid=190398Graham
