Very Nice NAD 7155 55 w/ch high current receiver
geppy1
geppy1 Posts: 3,076
edited October 2012 in For Sale (FS) Classifieds
For sale a very nice NAD 7155 receiver. This model was made by NAD between 1985-87. It features 55 watts per channel with 3 db of headroom and the abiltiy to put out way more power/current into low impedence loads. It even has an impedence selection switch to optimize the power supply. Has a record out selector, inputs for Phono (MM or MC), CD, Tuner, Tape 1 and Tape 2 and can handle two sets of speakers. . Also preamp out and main amp in terminals to allow one to use a larger power amp or bridge this unit and use it with the NAD 2155 power for biamping. Other features include mode switch, loudness, low filter , bass EQ and -20 db muting.
The AM/FM tuner is the outstanding Shotz tuner which is one of the best tuners ever put in a reciever.
The receiver is in very nice shape and everything works as it should. It needs nothing. The front panel is clean with the bottom left corner having a very very slight ding on the very edge.as. The rest of the case is very nice with a slight discoloration on the top left.. The original power cord has been reattached as I use a detachable cord with my gear. Asking $165 or BO Thanks,KG
006.jpg 542.4K
007.jpg 523.5K
008.jpg 508.9K
009.jpg 515.5K
010.jpg 519.6K
011.jpg 519.8K
Post edited by geppy1 on
    mhardy6647 Posts: 35,190
    edited October 2012
    Had one of these for a while (another Polk Forum denizen has it now); this is a very nice piece of hardware with some cool features (the NAD 'soft clipping' which can be switched on or off, variable phono loading, MM and MC compatibility, etc.)
  • erniejade
    erniejade Posts: 6,321
    edited October 2012
    Excellent receiver! Sounds much bigger then 55 WPC I used to have one. The phono pre is also way better than people would think.
  • geppy1
    geppy1 Posts: 3,076
    edited October 2012
