Variable TV mount.
badchad
badchad Posts: 348
edited October 2012 in Electronics
Is there such thing as a tilting TV mount that can accommodate both a 65" and/or 80" flat panel?
I have a 65" Panasonic plasma on the way, and I plan on wall mounting it. However, I'm familiar with the "upgradeitis" beast, and can imagine moving to an 80" set in the next 3-4 years.
If possible, I'd install the wall mount once, then simply swap out the TV. However, the majority of mounts I've seen in brick and mortar stores only accommodate a relatively narrow size range (e.g., 50-55" or 65-70").
Amazon has a Sanus mount that (supposedly) can accommodate 26-90" http://www.amazon.com/Sanus-VMPL3-B-Mount-Displays-Black/dp/B0008GP880
Any opinions and/or advice from the polkies?
Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
Oppo BDP-103
Post edited by badchad on
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    Have you ever thought of stickihg with your 65" and just eventually upgrade to a projector for anything larger? Maybe run both like some people do and have a ceiling dropped screen over your tv when you want to use the projector? That way you can just skip the 80 and go to the 100+? just food for thought.
    HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
    Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
    2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
    Desk: QSC RMX850/Behringer B2030P
  • badchad
    badchad Posts: 348
    edited October 2012
    Yeah, I have definitely considered it. If I had a dedicated theater room I'd be more inclined to do that, but my living room is also my theater room (currently). I know I'm stuck in my old school ways of thinking where projectors used to have a relatively inferior PQ.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
    EndersShadow Posts: 17,722
    edited October 2012
    Take a look at how this guy got it to work.
    If I was you as stated I would skip upgrading to a 80" TV. If I am ever going to go larger than my 60 it will be to a PJ and keep the 60 for normally TV viewing.
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    I love seeing dedicated builds like that. Makes me wish my lease would hurry up and end so i could go house shopping.
