Tweeter
Systems
Systems Posts: 14,873
edited May 2004 in Car Audio & Electronics
Hey all i live up here in Albany NY and work at a tweeter store which is based out of Canton Mass but either way we just started carrying polk which i thought we should have been for a while and am quite excited about the whole idea and i have called polk up and they are also very excited and also i have been reading some of the posts and to be quite honest cc and bb dont carry the greatest products and tweeter does sell some of the higher line such as JL, Boston, MB Quart, too name a few and Now polk oh and by the way i cant wait to deck my truck out with nothing but Polk MOMO
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,735
    edited May 2004
    so Polk DID go to tweeter
    i knew it
    damn it, theres no tweeters within like 2.5 hours of here...
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2004
    is there a dealer locator for them?
  • exalted512
    edited May 2004
    http://www.tweeter.com/corp/index.jsp?page=storeLocator
    nearest one for me is 6 miles away from houston...
    so i like, not 2.5 hours, more like almost 4
    -Cody
  • Jstas
    Jstas Posts: 14,978
    edited May 2004
    You can sign up to recieve Tweeter's mailer catalog and order stuff straight from the catalog too. So if you don't have a tweeter near you, you should be able to sign up for thier mailer and get all the stuff in the store through mail/phone order.
    Expert Moron Extraordinaire
  • AustinKP
    AustinKP Posts: 861
    edited May 2004
    Oh, that's just great! Closest tweeter to me is 457.0 Miles...
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • exalted512
    edited May 2004
    well i probably wouldnt buy from them either way, sounddomain is usually cheaper
    but the point is i wont be able to listen anymore:(
    -Cody
  • swerve
    swerve Posts: 1,862
    edited May 2004
    2-3 hour drive for me.... basically all the ones are in chicago or northern illinois that are accesible to me
    -adam
    cats.vans.bag...
  • Systems
    edited May 2004
    ALL YOU GUYS SHOULD ALSO TRY LIKE HIFIBUYS OR SOUND ADVICE IF YOUR MORE SOUTHERN CAUSE TWEETER OWNS THEM BUT IF NOT I DONT KNOW WHAT TO SAY OTHER THEN YEAH TWEETER.COM
    Testing
    Testing
    Testing
  • AustinKP
    AustinKP Posts: 861
    edited May 2004
    Good info minus the screaming :) Out of curiousity, do you happen to use AOL?
    Alpine 9815
