Computer starts boot up, then freezes
mdaudioguy
Found my computer off this morning, when I know I never powered down yesterday. Attempts to start up, but boot procedure stops just before loading Windows - the routine seems normal prior to that. Still powered on, it won't respond to a press of the reset button or a long press of the power button. Only thing to do is use the on/off switch on back of the power supply. Sound like a motherboard problem? Ideas or suggestions?
Post edited by mdaudioguy on
If it won't even respond to the reset button or holding the power button, that could either be a motherboard problem or a power supply problem. However usually if the power supply is bad it won't even attempt to boot up, so it seems the motherboard is the more likely culprit. I'd see if you can boot from a CD, preferably one with diagnostic tools. Since it gets to just before loading windows, it could be your HDD controller that's fried. If it will recognize and boot from the CD drive instead you can use it to diagnose the issue, possibly.
Monster AVL-300, HTS-2500 MKII -
Check if bad memory, bad HD or possible Windows OS corruption. We get something similar every few weeks and thats typically what it is. Just some suggestions.
Edit: Sorry did not see the part where you said it powered down on its own, it still can be a bad PSU I have seen them where they still let you power up but then cause all sorts of Havock. The Dells we work with its the number one part we replace under warranty.Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels -
Always start @ simple. Make sure your power supply fan is clean and moving enough air. Dirty fans and fins are your first enemy.
Vista??
I went through something very similar a couple of weeks ago, turns out I had left an SD card in the reader:redface:I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Try starting in safe mode.
Mine's been doing the same thing lately, I haven't found a solution yet either..TV - LG 42" LED
Receiver - Pioneer VSX-521
Front speakers - Polk Monitor 40's Series II
Center - Polk Monitor CS1 Series II
Surround - Polk Audio OWM3
Subwoofer - JBL L8400P
"I was born with music inside me. Music was one of my parts. Like my ribs, my kidneys, my liver, my heart. Like my blood. It was a force already within me when I arrived on the scene. It was a necessity for me-like food or water."
~Ray Charles~ -
If the reset button or holding the power button doesn't do anything, then it's not a software issue.
Can you get into bios setup? If not, definitely a hardware issue. If you can, try booting to an optical disc. If that works, you may have either a hard drive issue or just a corrupted image.
Things to do: Run Memtest (checks hardware and memory). Run hard drive diagnostics (choose the program based on your disc manufacturer). If that all checks out, you might just have to reformat and load Windows from scratch. -
Does any thing at come up on the screen when you first turn it on? Does the hdd light flash, stay solid, or not come on at all? What brand and model is it.
I think the problem was the power supply. Played around with things a little today, unplugging and replugging components, just to make sure everything was connected securely. Hit the power button and it booted up right into Windows! Thought everything was ok, and then after about 5 minutes, bam, it just cuts off - wouldn't come back on again either. Swapped out the power supply with one from a different computer, and I've been up for at least an hour now... We'll see if it stays that way.
Number one thing we replace under warranty faulty psu can play all kind of tricksLiving Room
Fronts: RTi A7's
Surrounds: Rti A3
Agree, my old computer did the same thing, had me thinking it was the MB going out ,but thought it was possibly the psu. Swapped out an old power supply unit from another old computer we had collecting dust and it powered it up just fine.
