STA 12B's--convert to banana plugs?
laotzu61
laotzu61 Posts: 327
Is there any way to convert my STA 12B's to a banana plug input, rather than non-terminated speaker cable; and would it make an audible difference if i can? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
  • SDA1C
    SDA1C Posts: 2,072
    edited September 2012
    Ummm. SDA2B or RTA12B? Aren't those a 5 way binding post already?
    Too much **** to list....
  • laotzu61
    laotzu61 Posts: 327
    no; bare-wire hook-up only.
    pitdogg2 Posts: 27,136
    pictures or it is going to be hard to believe
  • laotzu61
    laotzu61 Posts: 327
    i have some non-terminated cable i ordered from blue jean coming monday or tuesday. i'll take some pics then. because of the way i have my stuff set up, i try not to move any of it around unless i absolutely have to. i'll take some pics of that, too. thanks for the input.
  • soundfreak1
    soundfreak1 Posts: 3,414
    He may have plugs in the end of the binding post and not realize they can be removed?????? The should be 5 ways on there!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
