Updates gone bad...
    VR3 Posts: 29,549
    edited September 2012
    This isnt a modification mistake or really my mistake but -
    At my job we carry 1/4 speaker cables (live sound) and the company, not to be named had put so much solder on the connections that they + and - were actually touching...
    I think it goes without saying that did not end well and scared the crap out of me...
  • dromunds
    dromunds Posts: 10,138
    Pittdog2, have you ever re-glued surrounds that were still in pretty good shape but not rotted? I have some AR's that separated from the woofer cone (not all around) but the surround is not rotted. Is it worth it to try to just re-glue, or is it preferable to simply start over and re-surround?
    pitdogg2 Posts: 27,312
    dromunds wrote: »
    I have not but it's worth a try you really have nothing to lose. Most of the glue used looks like Elmer's but it's not. I would try just a little contact cement on both sides. Most know contact cement only sticks well to other contact cement so that is why you need to put on both. Really i wonder why it came loose? that usually doesn't happen.
  • Thorton
    Thorton Posts: 1,324
    I was about 13 or 14 and my older brother asked me to hook-up his new equalizer for him. I read the directions twice which didn't make sense and then hooked it up according to the directions. When I turned on the system, the most awful extremely loud snap, crackle and pop came out of the speakers. My brother face turned tomato red and I thought he was going to kill me. I then hooked it up the way I thought it should be connected and whala perfect sound. Since then my brother always calls me on any tech. advice.
    _____________________________________________________________________________________
    AVR: Denon AVR-3805, AMP: Parasound Model 2250, Front: Polk RTIA7, Center: Polk CSIA6, Surrounds: Polk FXIA6, Sub: Polk DSW PRO660WI
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • cwsmith68
    cwsmith68 Posts: 434
    Go to Wal Mart and get some Kraft glue. Elmer's makes their own variation of this and it works well.
    I had a pair of Realistic T-100 speakers that did the very same thing. Just glue them back down with Elmer's Kraft glue and they will be fine.
    Main system:
    Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
  • drumminman
    drumminman Posts: 3,396
    SDA1C wrote: »
    Don't you know. They have never blown up or wrecked anything. That's how they are so knowledgeable, by never learning anything. ....red plugs for example. I was learning the remote on my TGP3 and hit the PL2 button and cooked my center channel tweet. Like sparks and everything lol. iI happens. I wonder where that smoking driver pic is? That was a good one.
    I remember someone posting a pic here of a fried tweeter - and man, it really was fried! Was that you?
  • drumminman
    I rebuilt Xovers on a pair of speakers once, my first rebuild. Everything went great and then I connected them. They just didn't sound right, kind of like a really good am radio :redface:
    I called up the guy I bought the caps and resistors from and described what I was hearing, but his suggestions on fixing it didn't seem correct. I stared at the schematics for a long time and realized I had soldered a resistor in the wrong spot. Fixed it and, Voila! Beautiful sound.
    Didn't mess up anything permanently, but those speakers sounded awful until the Xovers were fixed.
  • nspindel
    nspindel Posts: 5,343
    Not particularly relevant as it didn't happen during a mod, but entertaining nonetheless:
    http://www.polkaudio.com/forums/showthread.php?121883-I-just-fried-one-of-my-1C-s.-Like-literally-smoke
    Ah yeah, that was a fun weekend.....
  • Saftgeek
    Saftgeek Posts: 114
    WOW! A picture is worth a thousand words! That is crazy! I am going to read that one post by post... Thanks for posting it up.
    -Saftgeek
  • nspindel
    Funniest part of that is that the speaker went POP and started smoking, and my first reaction was to take a picture to post up here!
  • drumminman
    :cheesygrin:
    I would have been too freaked out to react that quickly! :lol:
  • yeahbuddy
    yeahbuddy Posts: 115
    Also can't speak to any disastrous mod scenarios, but I do have an SDA mod sob story:
    I picked up a pair of stock SDA 1A's that were sitting in my (now ex-) girlfriend's mom's attic for about 10 years. My first 'real' set of speakers, I was pretty excited, and promptly went to google to figure out what they were. I was consequently directed here and my wallet hasn't been as heavy since. Assured by the gf that they were indeed my speakers, I went on to add Larry's rings, dynamat, armaflex, disconnect the SDA tweeter, and predictably they sounded remarkably better.
    I had been saving up for a crossover upgrade when we broke up and she asked for them back. That's when this story takes a turn toward the tragic. These speakers that got me into audio, that I babied and put a number of dollars into, were taken from me a few weeks back despite my pleads and offers of money. Worst of all is the fact that in a household of four women, there's no way they are in use, and will likely be either in an attic somewhere or brought to goodwill for a tiny tax rebate...what a waste. :cry:
  • drumminman
    To quote Captain Kurz from Apocalypse Now:
    Oh, the horror, the horror. . . . .
    :sad:
  • yeahbuddy
    drumminman wrote: »
    :sad:
    Horrific indeed. :eek:
    I'm just waiting for her to give me a call for advice hooking them up, at which point I'll inquire nspindel about exactly how I can start a fire in their living room... :twisted:
    OK, let's be honest, I would never do that to a beautiful pair of Polk speakers...
