Rip in the rubber surround of a mm6501
RSTERN
What to do? No problems a low volume , just at louder volume it rattles. Is there a place where i can replace the mids like Parts express and what would i look for?
Rob
Rob
mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
Post edited by RSTERN on
If it is not to bad you can take silicone caulk and kind of glaze both sides of the cut, dont over do it though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
its about 2 in long. still not sure how it got there. might give that a try before replacing.
Thanksmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
2 Inches... ouch, I would do super glue for a fast dry then lightly caulk to seal- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok, thanks for the helpmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
48.00 brand new replacement for club polk members through polk audioHello Kitty am/fm CD player
oh, thats not bad at all. might just do that to solve the prob. Thanks guys
Robmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
I think BAdchad is thinking of SDA woofers - the MM series most likely will not be that inexpensive- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I thought I read on here before, that polk will only replace it if its on a subwoofer 10" of bigger.
No warranty here, did it myself somehow, . Prob will temp repair it and order a new one to replace it.mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
