ground wire for my tt.
SDA1C
Need a 15 ft piece of ground wire. any scrap lying around would be great. It'll be covered so color doesn't matter. Good spun copper would be best. Of course I'll buy it .....
Thanks, 1C
Thanks, 1C
Too much **** to list....
Post edited by SDA1C on
You only need to run it to your preamp.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
yea i know my tt is in the corner about 12 ft away from the rest of the rack.Too much **** to list....
Couldnt you just use a piece of speaker wire?Hello Kitty am/fm CD player
I am looking for something like oxygen free spun something or other. Just a scrap that someone wants to make a buck or two on. Left overs if you will that'll just hit the heap anyway. Not a huge issue just thought I 'd check before I buy elsewhere. Some of these cable building guys must have some scrap on a roll of ultra fine spun 14 gauge or Teflon lying around somewhere.Too much **** to list....
For a ground wire? Use the cheapest stuff from radio shack, it'll be fine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yea i know. i just wanted something a little better for the fuzzy factor. i was hoping for something like 12 gauge car audio ground wire or something.Too much **** to list....
