NAD early pre amp to power amp metal links
geppy1
geppy1 Posts: 3,076
edited September 2012 in Wanted (WTB) Classifieds
WTB NAD early pre amp to power amp metal links. 3020/7020 3140 3150 3155 Monitor series . These would be the curved U shaped ones. I know I can use a patch cord or Audioquest ones (I have those) but those do not always sound right . On some gear it helps on other pieces it thins out the sound. let me know Thanks. KG
Post edited by geppy1 on
  • DaveHo
    DaveHo Posts: 3,582
    Have you tried making your own? Get some bare 8 gauge copper, bend it around a suitable object(a round 3/8" rachet handle works), trim it & you're done.
    A guy I bought a NAD from made his own out of heavy gauge "silver" wire to gold plated ends. Sounds pretty darn good!
    cnh
    heiney9 Posts: 25,492
    Try these, I use them on my Pass Labs Aleph 30 and Adcom GFP-750. High quality
    http://www.dedicatedaudio.com/inc/sdetail/115/5157
    EDIT: Nevermind wrong solution you need preout/main in shorting caps. These will be too small. Poke around the Dedicated Audio site, you might find something that will work
    heiney9 wrote: »
    Those look interesting, in any case, Brock!
    cnh
  • onebadchad
    onebadchad Posts: 364
    Just open the case and solder the leads together, done deal.
    Hello Kitty am/fm CD player
    cnh wrote: »
    cnh
    Yes. They are shorting caps for balanced connections that need to be shorted in order to use the single ended connections.
    Gold plated, solid brass. Typical Cardas build quality. I bought spares just in case too.
    These would certainly work, and probably sound better than the stock shorting bars. Not cheap
    http://www.dedicatedaudio.com/inc/sdetail/115/5274
  • DollarDave
    DollarDave Posts: 2,575
    Or, PM Pepster.
