What ceiling mounts are available for bookshelf speakers
polkfarmboy
I have a problem with my installation regarding my side surround placement and the best option would be to drop these down from the ceiling. Has anyone used such a method here? If so what mounts did you use?
Post edited by polkfarmboy on
I used these to hang some Monitor 40's and they are doing well. http://www.omnimount.com/products/speaker_mounts/stainless_steel_series/30.0_ca-mp/
cowtrimmer wrote: »I used these to hang some Monitor 40's and they are doing well. http://www.omnimount.com/products/speaker_mounts/stainless_steel_series/30.0_ca-mp/
Those were the only ones I could find too but I was looking for something that would drop them down a bit lower -
How much farther down ? They have a pretty sturdy mount at the base and the speaker. I would think that making the rod longer by 10" +or- a bit wouldn't hurt anything.
