New bulbs for Carver TFM-55 (works great then buzzz....poof!)
gwg_97
gwg_97 Posts: 332
edited November 2012 in Electronics
Well I got the new meter bulbs for my new to me TFM-55. See the smaller clear ones and blue ones in the photo (next to the old larger clear bulbs). I soldered them in place and fired it up. All is well, the lights work on both the normal and dimmer setting. Cool! That was easy! I'm feeling pretty smart!
OK, I wasn't satisfied with the light's compromised (broken) pin connection to the pcb (it was that way when I opened up the amp), so I added some heat and pushed what was left of the broken pins out of the pcb a bit, then I added a bit more solder. Reconnected the wires to the pcb with the existing "pin connector" and fired it up again. I got that familiar buzz at start up (What! No lights!), I waited for the usual click (at 4 seconds) and instead I got a prolonged buzz, then "pop" with a bit of smoke from the right rear of the amp. Crap! Is that the dreaded "Carver smoke"?
Luckily both channels still work and the amp sounds fine. The meters also work except for no lights.
So much for my inexpensive new amp. I really don't want to spend $300 to get this guy fixed. Any ideas. From what I can see, nothing appears to be cooked in the amp. Weird!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Post edited by gwg_97 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited September 2012
    I would go over your work again too see if anything is ok. I'm a bit worried about "OK, I wasn't satisfied with the light's compromised (broken) pin connection to the pcb (it was that way when I opened up the amp), so I added some heat and pushed what was left of the broken pins out of the pcb a bit, then I added a bit more solder"
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • gwg_97
    gwg_97 Posts: 332
    Yeah, me too. Something definitely cooked. Here is a photo of the potential smoke area (see R218 at the center right of the photo and R208 at the upper center of the photo). I should note that the R218 area had a bit of white residue and black stain around it before I even touched the lights. Not sure about the area near R208.
  • Glowrdr
    Glowrdr Posts: 1,103
    Is that where you added some solder? It almost appears to me that R218 and Rx02 are connected
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • gwg_97
    gwg_97 Posts: 332
    The only place I added solder was on the light's pcb (inside the yellow circles). The leads on the other light are outside of the photo to the right. The orange and white wires in the photo were previously to attach to pins/wires on the pcb via a connector. That was broken when I opened up the amp. I simply cut off the old connector and soldered the wires directly to the pcb
  • Glowrdr
    Aaah - must just be the picture then. Should be an easy fix, less than $100 if I had to guess.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • gwg_97
    gwg_97 Posts: 332
    I called Rolland today. He is 10 weeks out. Bummer!
  • disneyjoe7
    I bringing to think the new bulbs draw more current, and blow some circuits. Just a thought...
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    pitdogg2 Posts: 27,035
    gwg_97 wrote: »
    Trust me his wait is worth waiting for.
  • gwg_97
    gwg_97 Posts: 332
    Yeah, that is what I figured. Not a big deal. Thanks for the heads up!
    disneyjoe7 wrote: »
    hows that happen? It's only going to get the current sent to it...right? If i remember right something like 6 volts is all that is sent to them.
  • gwg_97
    gwg_97 Posts: 332
    Yeah, I think its only 6v per lamp (12v total). I'm begining to wonder if the bulb change and the smoke were unrelated. Previous to changing the bulbs, I only fired the amp up a couple of times and it buzzed pretty loudly. I'm pretty sure that amp was sitting for years untouched before I bought it. Stranger things have happened.
  • ambiophonics
    ambiophonics Posts: 727
    Voltage and Current are not the same - the bulbs would draw whatever current they require - that's not to say the power supply can provide that amount of current. That being said, I bet that these are separate issues.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • disneyjoe7
    Thinking those resistors and or transistor is fried do to Current being drawn by the new bulbs.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Drenis
    Drenis Posts: 2,871
    Not sure where your nearest place is you can send your amp too.
    You could try Rob Galayda here in Winnipeg (http://musicalintegrity.com/). Carver's are his "thing" and it's where my serviced unit came from. It's also half the distance to Rolland's.
  • vijayl
    vijayl Posts: 258
    Is it fixed now. I'm in the exact same situation after replacing the bulb..
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • mwk455
    mwk455 Posts: 219
    Can you put the blue lights in all carver amps? The blue ones would match my other lights.
  • trav0810
    trav0810 Posts: 1,056
    mwk455 wrote: »
    In all of them that I know about! The guys on thecarversite.com are always changing their meter lights or led meters to blue.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
    EndersShadow Posts: 17,704
    trav0810 wrote: »
    Yeah I am thinking about keeping it simple and going with white on my M1.0t
  • trav0810
    Mine go blue...yellow....red. That wasn't a particular need for me, but that's what the guy uses who did my MK2 upgrade. It looks good. But I LOVE the big meters in the M500. If I hadn't already upgraded my M1.0t's I'd rather have a pair of 500's.
    Thorens TD320
    Modified Carver C-1
