connecting 2 MM120's to a C300.2 polk amp
HouseVega
HouseVega Posts: 3
edited May 2004 in Car Subwoofer Talk
I' ve got a question...
I GOT 2 MM120'S & the c300.2 amp.
With these 2 mm120's, could i parralel the bridged connection on the C300.2 polk momo amp to power these both until i get another c300.2 amp?
or how would anyone here recommend hooking these 2 subs up when the 300.2 polk amp is all i have to work with 4 now...(in a dual , sealed box close the the enclosure specs. for this sub)
thanx for any help,
rudy
Post edited by HouseVega on
  • exalted512
    exalted512 Posts: 10,734
    edited May 2004
    well its a 2 channel amp, you could just run one to each channel
    anything else youll fry the amp
    and its not going to give you much bump at all...
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2004
    actually, i'd run just one sub off the bridged amp, it might give you more volume than one on each channel.
